Thread: Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
Results 1 to 6 of 6
  1. #1 Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    Donating Users timboku's Avatar
    Montgomery, IL
    Do you need to upgrade your push rods for a xp cam with ls7 lifters and 130# springs on a double roller? If so what is the length with stock rockers and stock heads? 7.050 is stock length zzp sells a 3/8 push rod in 6.95 and 7.00 and recommends it for the heavier springs? I have comp cam 7.050 5/16th push rods in the old motor that I ran with 1.9s. Will those be good enough? Haven't seen any info on pushrods when upgrading a to a cam so just wondering.
    Thanks!
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Buy a pushrod lenght checker, measure and order pushrods as necessary.
  3. #3 Re: Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    I've seen people have to use 6.95" on that setup
  4. #4 Re: Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    Buffalo
    I am in the same boat. I can't do anything until the motor is assembled and I use the push rod measuring tool.
    I was recently informed the 5/16th should be all you need The larger 3/8th rods I was told have trouble in the l32/l26 heads? Not sure if that applies if you are using l32/l26 block and keep the l67 heads
  5. #5 Re: Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    Kemmerer, Wyoming
    I didn't do anything to my pushrods with the same setup except 90 lb valve springs. 5000 miles later no issues.
  6. #6 Re: Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    Montgomery, IL
    I will order a pushrod checker as engine is close to being done. Hoping.to reuse these comp stock.height ones. Thanks!
  1. Pushrods and lifters?
    By Loftus1995 in forum Turbo
    Last Post: 03-14-2015, 01:08 PM
  2. Replies: 28
    Last Post: 03-11-2015, 10:44 PM
  3. slp 1.8 rockers and springs and pushrods $250
    By 98gtp1000 in forum For Sale - Parts
    Last Post: 12-12-2014, 01:44 AM
  4. VS Cam..Pushrods/Lifters?
    By Blake71091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2014, 02:15 AM
