Thread: 3800 sc high ltft
Results 1 to 9 of 9
  1. #1 3800 sc high ltft
    Jul 2013
    adrian, mi
    Alright ive got a 98 gtp. 3.4 mps, headers, 1.9 rockers, open cone, 104al, zzp tune . recently scanned and saw loss of boost and increase in kr. went from 9.5-10psi to down around 8psi at wot and under 2*kr to around 5. also ltft are stuck at 16.4. wondering what a couple possible causes could be. vac leak fueling issue ect. also getting random lean codes.
  2. #2 Re: 3800 sc high ltft
    16.4 means you are lean so that explains the lean code/KR.
    what was your ltfts before the change?
  3. #3 Re: 3800 sc high ltft
    Kemmerer, Wyoming
    more than likely it is a vacuum leak. I have a propane blow torch that I use to check for leaks, just dont ignite the flame, and when the engine rpm changes from the gas entering the leak area that how you know. an exhaust leak could do the same thing, but wouldn't cause any random misfires.
  4. #4 Re: 3800 sc high ltft
    Jul 2013
    adrian, mi
    never thought to check before. didnt have any issues until latley. exhaust leak vac leak. will check vac leak soon. thanks guys. any other ideas please comment
  5. #5 Re: 3800 sc high ltft
    vac leak would be going to 0 ltft at wot
  6. #6 Re: 3800 sc high ltft
    Jul 2013
    adrian, mi
    scanned yesterday 16.4 ltft at idle. 7-8 at wot. stft and sensor 1 zero out at wot. normal?
  7. #7 Re: 3800 sc high ltft
    I wouldn't recommend going wot with those lt's..
  8. #8 Re: 3800 sc high ltft
    Bastard Reptile's Avatar
    Kansas City, MO
    Spray brake cleaner around the base of your blower, throttle body, and all of the vacuum lines. Monitor your STFT's when you do this, and you'll probably find the leak.
  9. #9 Re: 3800 sc high ltft
    Jul 2013
    adrian, mi
    much appreciated guys. will check back tonight or tomorrow with what i find.
  1. Ltft @ 16?
    By rperry435 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2012, 09:53 PM
  2. 3800 Rough Idle-High RPM
    By mjacob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 03:10 AM
  3. Likely cause of high LTFT's
    By jims05ss in forum General Tech Discussion
    Last Post: 05-06-2009, 12:35 PM
