Thread: dyno sheet for xp cam build
Results 1 to 20 of 40
  1. #1 Re: dyno sheet for xp cam build
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Both runs are on a 3.0 pulley. It was just way colder in the first video. Obviously, you can see that the valves floated.
    I can see the blip you mean and that shouldn't have happened but to say they went away with the 130s in that video comparison there's obviously a boost factor at play, and I would have liked to have seen a scan with a wideband AFR to see other factors were at play.
    I'm not trying to be a dick about it, don't get my intention wrong, but as mentioned I have a lot of first hand positive experience using LS6 springs and a lot of success, so someone telling me now that I was doing something wrong I have difficulty with without some very definitive rationale. You've given the best counter arguement so I'd like to know more.
    Email all inquiries to willoverkill@gmail.com!
  2. #2 Re: dyno sheet for xp cam build
    May 2008
    Schuyler, NE
    Quote Originally Posted by Overkill View Post
    It's not only me though. Lots of people have experienced the same thing I have. All the great engine builders will always recommend 130's. Tischler, PRJ, Janice, etc.
  3. #3 Re: dyno sheet for xp cam build
    Any links or names?
    PRJ would put 130s on anything, he and I had our fair share of bantering 10+ years ago. I can understand a motor shop like Tischler suggesting 130s for good measure but I don't know how many 3800s they actually set up from scratch or their long term results.
    Again my concern on the 130#s is quality, and timing chain life. I'd consider the PAC 1218 130#s, they have a good rep, but you'd never see CompCam 130s in my engine again due to failure issues, and Manley springs for the same reason. I don't think there's any timing chain on the market currently that you can anticipate will last more than a few short years, which 130s don't help with. I had extensive experience with GM LS6 springs without these issues, on 2.x pulley 12-13psi 6200rpm shift point cam and cam/rocker packages, no boost spike/valve float/trouble making horsepower issues, I never had a spring failure, I trusted the quality, I never saw a need to go for anything else. When I switched to Vortec valves, I ran 110# factory LS7 springs, again not an issue, they worked great, and I trusted the GM factory quality.
  1. Sheet metal intake?
    By wa04compg in forum Turbo
    Last Post: 08-20-2014, 06:10 AM
  2. Dyno Day $30 dyno pulls *now with FAIL* p3
    By danomite02 in forum Shows and Events
    Last Post: 10-01-2013, 04:44 PM
  3. 2007 Grand Prix XP Build 9/20/2012 Dyno Run UPDATE!!!
    By MidnightBlue in forum Members Rides
    Last Post: 09-21-2012, 12:29 AM
  4. Factory build sheet location?
    By txslow6 in forum General Grand Prix Discussion
    Last Post: 07-14-2012, 12:43 PM
  5. Carbon Fiber sheet?
    By robahr24 in forum General Tech Discussion
    Last Post: 08-24-2008, 04:39 PM
