Thread: Opinions/Info please
Results 1 to 5 of 5
  1. #1 Opinions/Info please
    SE Level Member Mvfootball1's Avatar
    Aug 2008
    Shoreview, Minnesota
    So here's the deal, I have a 98 GTP that is bone stock.
    In the next month or 2, I would like to do exhaust, intake, pcm, and 3.4 pulley.
    -I have some questions....
    1. What mods do i have to do before i can safely do the 3.4 pulley without breaking anything?
    2. Is it worth it to get a downpipe along with my exhaust?
    3. In lamens terms, what will a PCM do for me?
    4. Are all these mods "tranny safe?"
    5. Also, I need tires next month...Is it possible to go wider? maybe to a 235?
    Any suggestions or info/opinions would be great, on the tires as well
  2. #2 Re: Opinions/Info please
    Apr 2008
    Chillin at the Beach , VA
    1) headers, catted or non-catted dp, air intake, 180 t-stat, autolight 104 plugs, scan for kr, pcm or pcm tune. scan for kr.
    2) You don't need a cat back. The factory exhaust from there back is more than adequate. Get you a good set of headers which will come with a dp. Your choice of catted or non. Mufflers wont do anything for performance, but will give you a deeper tone.
    3) Will open up different ranges. Firmer shifts, higher redline, speed limiter removed, adjusted for the mods you have to try and help eleminate kr.
    4)I don't see you having any problems. But like anything else modded to a degree, enough dogging and things can tend to let go. If your a occasional racer or what not, you'll be good for now.
    5)Yes you can go to a 235. It's only going to be about a 1/4 to 1/2 inch wider at the most.
    I hope this helps and I am sure if I left anything out Others will chime in.
  3. #3 Re: Opinions/Info please
    Aug 2008
    Yeah that helps a lot, thank you. what is kr?
  4. #4 Re: Opinions/Info please
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    kr = engine knock
    Here
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  5. #5 Re: Opinions/Info please
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to the 3.8L SC section
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Opinions and info please
    By Mvfootball1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2009, 01:16 PM
  3. Head unit info/comparison, opinions, and specs needed
    By Trannyman95 in forum Audio, Security & Visual Electronics
    Last Post: 12-07-2008, 06:15 PM
  4. Mod opinions?
    Last Post: 08-18-2008, 08:07 AM
  5. Need a few opinions....
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-07-2008, 01:19 PM
