Thread: PCM control just engine or abs and body as well ?
Results 1 to 6 of 6
  1. #1 PCM control just engine or abs and body as well ?
    Mar 2015
    Ontario
    Im thinking of using the GTP supercharged engine in my porsche 914.T
    here are adapter plates to bolt to transmission.
    But curiosu
    does the PCM control just the engine ?
    If so i can just swap everything into my car and hit the key.
  2. #2 Re: PCM control just engine or abs and body as well ?
    the pcm for a 3800 will do both engine and the tranny. my guess is you'll need a pcm set up like a off road buggy would use.
  3. #3 Re: PCM control just engine or abs and body as well ?
    Right, controls both motor and transmission. No ABS, BCM stuff.
    BUT, the pcm will go into limp mode/security mode sometimes because the computer does not see the PK3 ignition key. A tune could shut off the security system features.
  4. #4 Re: PCM control just engine or abs and body as well ?
    Mar 2015
    Ontario
    Hmmmm, yes that seems right, or maybe a 5 speed PCM and theres no trans control to worry about...Did the GTP come 5 speed ?
  5. #5 Re: PCM control just engine or abs and body as well ?
    that can be done. you'll need a tuned pcm for all that.
    should be a interesting build for sure.
  6. #6 Re: PCM control just engine or abs and body as well ?
    i just saw your in Canada, xontact overkill he does tuned pcm's.
  1. Body Control Module
    By Larpi in forum General Tech Discussion
    Last Post: 01-04-2016, 10:42 AM
  2. Body Control Module going bad?
    By mntnbiker in forum General Tech Discussion
    Last Post: 01-03-2015, 06:57 AM
  3. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  4. body control module
    By allen in forum General Tech Discussion
    Last Post: 02-20-2012, 06:35 PM
  5. Body Control Module?
    By roxie in forum General Tech Discussion
    Last Post: 06-29-2011, 12:15 PM
