Thread: m90 difference 1996 vs 1998
Results 1 to 13 of 13
  1. #1 m90 difference 1996 vs 1998
    Sep 2013
    Massachusetts north shore
    What's the difference between the 1996-1997 pontiac supercharger vs the 1998-2003 other than the throttle body
  2. #2 Re: m90 difference 1996 vs 1998
    the 96 is a m62 blower, the 97-03 is a m90. its bigger and better.
  3. #3 Re: m90 difference 1996 vs 1998
    95-96 still had the gen 3 M90 if it was a series 2 motor. So bonnevilles and buick rivs had them.
    Just the vacuum ports are different really. I prefer the 98+ because it has no vacuum tree and only uses 1 single vacuum line to connect the BS, LIM and MAP.
  4. #4 Re: m90 difference 1996 vs 1998
    Bastard Reptile's Avatar
    Kansas City, MO
    97's had an extra vacuum port on it by the boost valve.
  5. #5 Re: m90 difference 1996 vs 1998
    The Boss Iceman6669's Avatar
    Jun 2011
    96s where an off white color and had the vacuum tree with THREE vac ports on it.
    97s were the standard gun metal color and had a vacuum tree with TWO vac ports on it.
    98+ were gun metal with no vac tree.
    2011 F-150 Yote powered
  6. #6 Re: m90 difference 1996 vs 1998
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I thought the '96's had the "danger to manifold" warning sensors?
  7. #7 Re: m90 difference 1996 vs 1998
    Jun 2011
    My 96 didnt have any extra sensors on teh blower.
  8. #8 Re: m90 difference 1996 vs 1998
    Cibolo, TX
    I take it you have seen F&F in a while?
  9. #9 Re: m90 difference 1996 vs 1998
    Kansas City, MO
    You call it gun metal.....I call it.....well, aluminum.
  10. #10 Re: m90 difference 1996 vs 1998
    Nov 2013
    United States
    96 Rivi owner here.
    95 Rivis and Bonnevilles were Series I L67s with the M62. 96+ Had the M90. The 95s and 96s had the 4T60E (vacuum and electric hybrid) while 97+ got the 4T65E-HD. That's why 96 3 vacuum ports. The fuel rails are also slightly different between 96 and 97+, but you can use a 96 blower on 97+ and vice versa. You just need to dick with the vacuum lines or just transfer everything over from your old blower to the new one. Throttle bodies were the same in 96 and 97+.
  11. #11 Re: m90 difference 1996 vs 1998
    Ice and Matt hit it pretty much on the head.
    96 Blowers had thermal coating on the entire blower, + 3 vacuum port tree by the TB. TB had an extra vac port for trans modulator 4T60
    97 Blowers had thermal coating only on the snout + 3 vacuum port tree by the TB and no port on the TB for the trans 4T65E
    98+ Blowers had thermal coating only on the snout, no vacuum tree by the TB and no port for trans 4T65E
    You can use any blower or TB from this combo as long as you take a moment and route vacuum properly. You can cap off the vacuum tree on 96/97 blowers and go with the 98+ version of vacuum lines. And the port on the TB for the modulator on the 4T60 is merely plugged on the later years. Pull the plug..toss a nipple in ...and presto you'd have the same port.
  12. #12 Re: m90 difference 1996 vs 1998
    Nov 2013
    United States
    Mine only had it on the snout. We bought the car at 48k so I doubt the SC was replaced.....
  13. #13 Re: m90 difference 1996 vs 1998
    Sep 2013
    Thanks guys I figured it out a few minutes after I posted this I noticed the different vac lines in a pic
  1. how much of a difference if any ?
    By speed demon in forum General Grand Prix Discussion
    Last Post: 09-12-2014, 08:18 PM
  2. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  3. Difference in NA s1x and SC s1x cam
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2012, 07:49 PM
  4. Difference in M90
    By jakeb157 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2012, 04:22 PM
  5. Difference between GTP and GXT... is there one?
    By kjclawson in forum General Tech Discussion
    Last Post: 08-09-2009, 12:34 PM
