Thread: My fuel pump and rewire project
Results 1 to 20 of 25
  1. #1 My fuel pump and rewire project
    GT Level Member Hardonyomom's Avatar
    aurora
    So i have a 01 gtp and got the 98 venturi bucket and racetronix pump. I have figured out how to put it all back together but running the rewire is tricky. I do not have the zzp rewire which looks like cake to just connect the wires and run like a sound system through the firewall. I have the prj kit which is better but more involved.
    I will post pictures here.
    The correct way from what im reading and see is to run it under the car(there are 20 zip ties) (the wire has plastic shielding tube covering it)
    Anyways, where does the factory wiring begin? if i can figure that out then i can snake my new wire down and start attatching it under the car. Only thing i can think of right now is to fish it behind the fuel pump toward the trunk and maybe it will drop down.
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: My fuel pump and rewire project
    aurora
    Here is how it looks now. I'm thinking that the factory wiring goes just behind the tank by the spare tire area but i need to look into it more. Again as always i like to post pics to help anyone out in the future that is getting the same thing done.
    Cheap zzp rewire HERE (believe me! if my rewire looked liked this i would probably just run it through the top and bend the fuel pump cover a little just like everyone is saying to do but i don't have a zzp one.
    PRJ REWIRE
    So anyways, STOP telling me to not run it under the car. This kit was designed that way and ill make it work ( I always do, whether its myself or other sources
    Here is a picture showing what im looking at . the front is lifted on jacks right now, which i think may be enough if i can snake the wire past the original wire. the original wire looks like it goes to the left of the pump if you are looking at it in my direction. you can stick your hand behind the middle though and there may be an opening to get the wire down there. Im gonna use a hanger and see if it works
  3. #3 Re: My fuel pump and rewire project
    GTP Level Member
    Jan 2015
    Lincoln, NE
    some pictures on the way...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  4. #4 My fuel pump and rewire project
    run it underneath the carpet
    04 Comp G.
  5. #5 Re: My fuel pump and rewire project
    GTP Level Member
    Jan 2015
    Lincoln, NE
    you can certainly go under the car but its more trouble then its worth...
  6. #6 Re: My fuel pump and rewire project
    aurora
    Yes im probably going to end up doing it that way, kinda makes more sense when something goes wrong. (or does it) i guess i havent physically put the pump back in the car yet and reattached the new wiring kit to see if it will be a problem with the fuel cover closing all the way but im sure i can make it work. I'll be at that step in a few. Just heating up the gararge till i wanna go back out.
    but it does make sense to me if i can get the wire to under the car im going to do i tthat way. ONLY question i had was where is an opening from in the car to under the car from the fuel cover. Thats it
  7. #7 Re: My fuel pump and rewire project
    GTP Level Member
    Jan 2015
    Lincoln, NE
    this picture is of the wiring goign to the fuel pump. as you can see the stock wiring is pluged into the racetronics harness and tucked back under the body.
    this picture shows the harness plugged in and also shown is the **** zzp rewire that is abandoned in the car.
    this picture shows where the optional boost a pump plug in landed in the corner of the trunk
    this picture shows where i mounted the relay to the decklid/back seat support
    this picture shows where i mounted the fuse and how power comes off the power post above the fuse block
    this is the grommet that my fuel pump harness goes through. also my 2 gauge power for my stereo stuff goes through here as well so it is plenty big. this is the stock grommet where the shifter cable goes through right behind the center of the motor. its pretty easy to get to.
  8. #8 Re: My fuel pump and rewire project
    aurora
    [QUOTE=NebTurboST5;1316133]
    this picture shows the harness plugged in and also shown is the **** zzp rewire that is abandoned in the car. ( SOOOO, you USED to have the zzp rewire and ditched it for the racetronix?) Do tell why so others know
    this picture shows where i mounted the fuse and how power comes off the power post above the fuse block (WE HAVE THE SAME BATTERY)
  9. #9 Re: My fuel pump and rewire project
    GTP Level Member
    Jan 2015
    Lincoln, NE
    [QUOTE=Hardlyaninch;1316142]
    Quote Originally Posted by NebTurboST5 View Post
    i ditched it because it was starving my 255 pump on the dyno when i was making the pull that netted 451 horse. i was up to 12.9 to 1 afr at 6300 rpm when it should have been 11.5 like the rest of the pull. i swapped it out and havent had trouble since. basically i came to the conclusion that it was no better then stock. i didnt have any more voltage at the pump. i never checked voltage or amperage under load of the stock wiring. so im not sure its just my suspicion.
  10. #10 Re: My fuel pump and rewire project
    Enfield, CT
    How is the ZZP rewire kit cheap? Reviews on it seem to be positive.
  11. #11 Re: My fuel pump and rewire project
    Should have a problem.. I ran a old ZZP rewire that way and was still able to put the cover back on.. Just take one or two of the nuts off if needed. I know you can run it underneath the car but imo.. Why risk water damage or damage from the elements or heat from the exhaust.. Rather have it underneath the carpet and not worry about it.
    04 Comp G.
  12. #12 My fuel pump and rewire project
    Lack of relay.. Look at it its very basic.. Let's be honest it's probably fine for most people but why not pay a little bit more and grab the better racetronix one.. I ordered one awhile back should be sitting in the truck of my car back in FL.
    04 Comp G.
  13. #13 Re: My fuel pump and rewire project
    Enfield, CT
    I see it has no relay but no one seems to have an issue. I'm asking because i'll be getting a rewire kit for the wife soon
  14. #14 Re: My fuel pump and rewire project
    aurora
    THANKS NEB!!!! exactly what i needed. I'm gonna run it through the top. Connectors were confusing at first but then i realized its a piggy back setup and they want you to reuse the plug that has the orange green and black wire. Ok i got this! I was just thrown off a bit when i said a GPONA thread about running it under the car. seemed simple but they never explained how they even got the wire from the top of the pump to the bottom. Thanks again guys
  15. #15 Re: My fuel pump and rewire project
    Just felt like a better kit.. I had both even though I haven't gotten around to installing the racetronix right off the bat I could tell it looked to be of way better quality.. ZZP is what $30-35.. Racetronix is $50-55. Up to you if the $20 difference is a deal breaker. Most of us spend enough time/money on mods where it shouldn't be a deal breaker.
    04 Comp G.
  16. #16 Re: My fuel pump and rewire project
    aurora
    yeah for 210 i got the fuel pump and rewire kit.
    Here are some pictures of the project now because this case is just about closed. Neb where did you run your ground to?
    MAD SCIENTIST AT WORK
  17. #17 Re: My fuel pump and rewire project
    Op what made you upgrade the pump?
    04 Comp G.
  18. #18 Re: My fuel pump and rewire project
    aurora
    Well i got problems. I used the 1998 bottom bucket for the venturi feed line, put in the racetronix pump, use the sleeve to go around the pump. On the 98 there is a yellow floating tube or compressed tube that fits in there ( it is NOT on the 01) goes right next to the fuel pump. I ran all the wires correctly. what i did not do was take the sending unit off of the 01 and use the same floating arm. I left that as is. Anyways, i put it all back together. turn the key over let it cycle and pump turn on for 10 seconds. did this a few times. finally turned the car on. it was slow to start because it was priming and then i had it running. ran for about 20 seconds. I shut the car off looked for leaks with the cover off. no leaks or anything.
    So before i took on this project i was very low on fuel. enough to wear the DIC says LOW but the HUD didn't say it yet. I go to turn on the key with the new tank setup and it shows 1/4 full (HHHMMMMM) i go to back it out of the garage and it died on me. I started it back up managed to get it in drive, it died. Put the car in neutral where it sits now in the garage. Not sure what i can do other than get some fuel and see if 5 gallons even makes the gauge move or car start but besides the point i would like my gauge to show im emtyp when im empty. NOT 1/4 full. Let me know what you think i should do.
  19. #19 Re: My fuel pump and rewire project
    Donating Users timboku's Avatar
    Montgomery, IL
    1) Pull the pump out
    2) Swap your old sending unit into the bucket since you know that it is a working sending unit
    3)Pull the pump assembly apart and reread the instructions. double check everything.
    4)Your pump should be priming if you can hear it. If you cycled it 10 times it should have started on the first crank since you "primed" the pump 10 times essentially. If it took time to start, it is not functioning correctly, check the hose from the pump to the top of the canister, sometimes they come loose, check, the check valves in the canister at the bottom to make sure they are not dry rotted the seals, this keeps the fuel in the canister, is the venturi port/line hooked up correctly???? My guess is the canister is not filling correctly and you are running out of fuel do to the assembly not put together correctly.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  20. #20 Re: My fuel pump and rewire project
    aurora
    Quote Originally Posted by timboku View Post
    Thanks, im going to take it all apart again at some point today or this week.
    It did take 2 seconds to start my first try and then i ran it for 30 seconds.
    I did let it prime a few times before starting it.
    Once it ran i let it run for about 30-45 seconds.
    I then waited a few mins to finish cleaning up and was ready to pull it out of the garage
    as i put it in reverse i made it about 10 feet then it ran out of fuel.
    I restarted it , it ran for about 2-3 seconds and shut off.
    I tried again it won't start so i got some problems here but ill take it apart and have questions later here.
  1. Fuel pump rewire 04+?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2015, 05:40 PM
  2. Wtb fuel pump rewire
    By BLUESMOKEGTP in forum Wanted To Buy - Parts
    Last Post: 09-13-2014, 03:44 PM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. fuel pump rewire
    By srt4vsgtp in forum General Grand Prix Discussion
    Last Post: 02-13-2013, 07:20 AM
