Thread: boost question
Results 1 to 10 of 10
  1. #1 boost question
    Jul 2014
    New Jersey
    Well i suck at searching on this forum, my question is for every one pound of boost how much hp is gained. And ever 0.1 drop is equal to 1 lb of boost correct?
  2. #2 Re: boost question
    Sep 2014
    Worcester, MA
    In general, for any supercharged motor, increasing pressure is essentially like increasing displacement.
    In theory that would be 1PSI=7% more HP... but in practice there are other losses, like parasitic HP to drive the blower, losses due to increased air temperature, etc.
    So there is a vague answer for your vague question
  3. #3 Re: boost question
    it dont work like that at all. higher boost dont mean higher HP. thats just the restrictions.
    i had like 7 to 8 psi stock, headers took 3 psi away, car felt stronger with less boost psi cause it was flowing better. now with a 3.4 i see 10 to 12 psi. if i had better flowing parts like heads, dual exhaust, cam ect ect, it would be less psi. and feel even better is my guess.
  4. #4 Re: boost question
    Sep 2014
    Worcester, MA
    BTW I am figuring that is 7% over NA horsepower. You will gain a lot less (percentage-wise) going from 13PSI to 14 PSI.
    And don't forget that PSI is measured in absolute terms (atmospheric pressure is 14.7PSI) - so going from 13 PSI to 14 PSI is actually going from 27.7PSI to 28.7PSI. Then if you calculate 28.7/27.7, that's only a gain of 3.6%. And of course your actual gain will be less than that because of increased heat losses as you go to higher boost... yada yada yada yada
  5. #5 Re: boost question
    Feb 2013
    37.295091, -121.930053
    i want real math proof of what your saying sunshine
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: boost question
    Ricer math does not apply.
    Every car is different and flows differently.
    It's all about velocity and correct pulsation/scavaging of the exhaust system.
    If my car flowed better at 4psi and had no knock, I'd make more power than your knocking car that makes 7psi of boost.
    The end.
  7. #7 Re: boost question
    The Boss Iceman6669's Avatar
    Jun 2011
    Running high boost sure makes the low end fun though.
    2011 F-150 Yote powered
  8. #8 Re: boost question
    Jul 2014
    New Jersey
    Okay i just wanted to learn, i figured the more i know the better
  9. #9 Re: boost question
    Quote Originally Posted by Iceman6669 View Post
    Sure, until 3500~ RPM when everything knocks to kingdom come and it makes 105 horsepower.
  10. #10 Re: boost question
    Jun 2011
    Pfft
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost question
    By SLICK4TIME in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2014, 10:37 PM
  3. boost question
    By JPGgtp in forum General Tech Discussion
    Last Post: 06-11-2013, 11:00 PM
  4. boost question
    By james gilbert in forum General Grand Prix Discussion
    Last Post: 03-18-2013, 05:16 PM
  5. boost question
    By str3etgl0w in forum General Tech Discussion
    Last Post: 07-20-2012, 11:14 PM
