Thread: Hvac
Results 1 to 6 of 6
  1. #1 Hvac
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I was wondering where the red vac line goes in this diargam? I can have my fan on high, and i really dont feel anything coming out. Where does the vac line come into the car at?
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  2. #2 Re: Hvac
    to the pas side firewall, down the fender, under the fuse box into a harness unto the car to a box.
    if you dont feel air blowing any where the fan or resistor is bad. that vac line is what power where the air blows from, def, vent, floor.
  3. #3 Re: Hvac
    The fan works fine. Im not getting any change from def, floor etc. So the red vac line is what i need to look at?
    Mods- Intake
  4. #4 Re: Hvac
    its where to start. if the line is not broken, then you goona want to open up the glove box and the under the drivers side column, then car on, change the air flow, watch the round pumps in the dash, the arm in the middle moves up and down to change air flow. its got plastic linkage that breaks. theres one on both sides.
    if thats all ok, its the box the vac line leads too from under the hood, or the climate control its self.
  5. #5 Re: Hvac
    ok. I have duel digital control. Same process?
    Mods- Intake
  6. #6 Re: Hvac
    yes.
    theres been a number of threads where it was the box under the dash, or the climate control were bad.
    if you search around here for old threads, that boxes name and part # are listed. or grab one from a junk yard.
  1. HVAC Controls
    By Below Average Joe in forum General Tech Discussion
    Last Post: 09-27-2011, 07:26 AM
  2. DIC HVAC gone..
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-07-2011, 10:03 PM
  3. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  4. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  5. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
