Thread: heads and cam install
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 heads and cam install
    Kemmerer, Wyoming
    ive researched doing a cam install, and decided it would be easiest to lower the engine/transmission down enough to get access to the front cover. But, I am also installing a set of ported heads so my question is, how much more work is it to just drop the entire engine and transmission to work on without having to lean over anything. is the extra labor of removing the engine and transmission from the car going to justify itself because of the ease of access?
  2. #2 Re: heads and cam install
    you could just take the engine out so much quicker.
  3. #3 Re: heads and cam install
    Kemmerer, Wyoming
    take the engine out the top or lower the eng/trans on the cradle?
  4. #4 Re: heads and cam install
    engine out the top. put it on a engine stand, enjoy the freedom of walking and working around it.
  5. #5 Re: heads and cam install
    Pssh drop the passenger side of the subframe a bit and remove the HB/timing cover.. No need to worry about extracting the freon and can easily be done withing a few hours.
    04 Comp G.
  6. #6 Re: heads and cam install
    noob, lol unbolt compressor and p/s pump. out she comes.
  7. #7 Re: heads and cam install
    Or you can do that
    04 Comp G.
  8. #8 Re: heads and cam install
    But now that I think about it might be easier to pull the motor and go ahead and change the rear main seal and address the often leaky oil pan
    04 Comp G.
  9. #9 Re: heads and cam install
    Kemmerer, Wyoming
    I'm just going to let the mechanic decide. there are pro's and con's to either method. I'm just trying to gather information to help him decide. I'm going to drop it off on monday, a week from today, and if he has time to get started on it that day or the next day I can help him by taking the top stuff off and putting the new heads on.
  10. #10 Re: heads and cam install
    #1 why is someone else doing the work?
    #2 out the bottom if its on a lift.
    #3 out the top if you don't have a lift.
    #4 disconnect ps pump and Ac pump leave the lines for each connected. AC does not need to be recharged. Ive don't plenty engine and trans swaps not a single time ac had to be messed with.
    #5 do the rearmain and pan gasket while its out, cheap piece of mind.
    #6 um please explain #1 to me again, your easily going to double the cost of this project with labor cost......
    #7 IMO id rather screw up my own car rather than blame someone else LOL!!
  11. #11 Re: heads and cam install
    Kemmerer, Wyoming
    I really really hate working on my car. the mechanic that will do it will get it done much faster than I will be able to, and he dosent charge much because I get the friends/military discount. I also dont have all the tools I would need to get the job done.
  12. #12 Re: heads and cam install
    May 2008
    Schuyler, NE
    When you are doing heads, I would just pull the motor.
  13. #13 Re: heads and cam install
    ^^That.
    Pulling the motor is going to make life a trillion times easier.
    And that is surveyed statistics according to the reading of GPF, chapter 12, verse 3-5.
  14. #14 Re: heads and cam install
    The Boss Iceman6669's Avatar
    Jun 2011
    Really? Swapping heads was fairly easy with the motor in the car.
    2011 F-150 Yote powered
  15. #15 Re: heads and cam install
    No thanks.
    I'd rather unbolt the exhaust and yank it all out the top.
    1 hour.
  16. #16 Re: heads and cam install
    Jun 2011
    I just don't understand the need to spend the extra hour. What was so hard to you about doing in in the car?
  17. #17 Re: heads and cam install
    Work smarter, not harder.
    Yanking heads in the car, leaning over everything.
    No thanks.
    I like just tossing it on a stand and doing everything easy, peasy.
  18. #18 Re: heads and cam install
    the hell with all this nonsense out the bottom for EVERYTHING as long as you have a lift obviously.
  19. #19 Re: heads and cam install
    #poornolift
  20. #20 Re: heads and cam install
    May 2008
    Schuyler, NE
    Leaning over the fenders for a couple hours scraping headgaskets and cleaning bolt holes is pretty hard on the knees and back.
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  3. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
