Thread: Only 3.3 lbs of boost?
Results 1 to 16 of 16
  1. #1 Only 3.3 lbs of boost?
    Jul 2011
    Baltimore, MD
    Think i finally got this damn thing running after the tune. Now im only reading a little over
    3lbs of boost from the torque app and my boost gauge. I have replaced the bbv cause it
    was broken. I just rtv'd the i/c and the charger. Not sure if i used the right stuff though.
    I used the clear rtv. Im hearing a hiss from the back of the motor. So im not sure if the
    rtv did the job. any thoughts?
  2. #2 Re: Only 3.3 lbs of boost?
    May 2012
    Where winter never ends
    mods? What size pulley?
    2000 Regal - Winter Beater
  3. #3 Re: Only 3.3 lbs of boost?
    Jul 2011
    Baltimore, MD
    03 gt. l67 swap w/gen v. ssic, 3.25mps, pacesetters, tb spacer, fwi, autolite 104's dhp tuned
  4. #4 Re: Only 3.3 lbs of boost?
    is it idling ok? or does it have a high idle or stalling going on?
    you can spray some carb cleaner at the IC and blower base while its idling, if the idle jumps up you found your leak area.
    never seen clear rtv.
  5. #5 Re: Only 3.3 lbs of boost?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    maybe he used a hot glue gun lol. Never seen clear rtv either. Check your STFT/LTFTs (fuel trims) if you see +16.4 you have a vacuum leak.
    04 GTP -HAI, 1.9 rockers.
  6. #6 Re: Only 3.3 lbs of boost?
    gardner,mass
    Clear rtv is the same as black, they sell it at every auto parts store.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  7. #7 Re: Only 3.3 lbs of boost?
    SE Level Member oldsman105's Avatar
    Queens, New York
    Bypass the BBV solenoid. I will bet you get full boost back.
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  8. #8 Re: Only 3.3 lbs of boost?
    May 2008
    Schuyler, NE
    ^^that's your problem.
  9. #9 Re: Only 3.3 lbs of boost?
    Never Never Land
    I had a similar issue on my 99. Couldn't make boost to save its life. Dog slow. Crappy fuel mileage. Shifted funny. I unhooked the vac line from the BCS. BCS was shot. I never did replace it though. Like 25K later and still has the vac line disconnected.
  10. #10 Re: Only 3.3 lbs of boost?
    SE Level Member jimzssei's Avatar
    Sep 2014
    I'd still investigate that hiss
  11. #11 Re: Only 3.3 lbs of boost?
    Check LTFT's like stated.
    If IC'd, I'd wonder if the PCV is done correctly.
    Also, yes...BBV needs to be vented to the atmosphere.
  12. #12 Re: Only 3.3 lbs of boost?
    Jul 2011
    Baltimore, MD
    It idles high when i first start it up in the morning, but after that its ok.
    LTFT-16.4 (so im guessing there is a leak somewhere)
    STFT-20
    Its a Gen V on a Gen III core if that makes any difference. I've read about the pcv mod, but
    i was going to run a breather instead. Yet, when i installed the breather the car ran worse.
    and on the back of the gen v there is a hole that looks as though something should be connected
    there.
  13. #13 Re: Only 3.3 lbs of boost?
  14. #14 Re: Only 3.3 lbs of boost?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Boost bypass solenoid or MAP sensor is my guess. Or that vacuum leak ;P
  15. #15 Re: Only 3.3 lbs of boost?
    Jul 2011
    Baltimore, MD
    ok, just came from blocking the bbv and replacing the map...again
    went for a drive and still only reached 2.7 lbs of boost. everything
    is tight. still gotta find that vac leak, could that be the end of the
    road?
  16. #16 Re: Only 3.3 lbs of boost?
    Nov 2013
    United States
    I had a similar problem in my Rivi, only making a couple pounds of boost at WOT. Turned out to be a blown EVAP purge/vent fuse. On my car it was on the fuse panel on the drivers side of the dash, should be in a similar/same spot on GPs. This fuse is also inline with the O2 sensor in the rear manifold (at least on Rivi's). I was throwing a few codes for it though, but you never said anything about any codes.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
