Trying to gather some opinions.
One of my cars, 2000 Bonneville SLE, Topswapped, had a clogged cat and ended up chipping a piston. It still runs good, just burns quite a bit of oil and has about 40 psi of compression in cyl 2.
my other car, 00 camaro, also topswapped, spun a bearing due to water getting in the oil.
Should I be able to just take a piston out of the camaro and put it in the bonneville?
Would I be able to reuse the rod bearing, rod bolts etc? Or should these be replaced.
I would basically follow this procedure http://www.3800pro.com/forum/general...ement-car.html
But also remove the rear head, pull the piston out, etc. Correct?
