Thread: p0341 DTC ?
Results 1 to 2 of 2
  1. #1 p0341 DTC ?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I I found out i have a p0341 code. (camshaft position sensor A circuit range/perfromance bank1 or single sensor code. Obviously this has to do with the cam sensor.
    I have read that it can be caused by frayed wires, or the sensor failing, or a bad reluctor on the Cam. Which of this is most likely? is there any way i can check before dropping cash on a replacement sensor?
    my car is also running bad (intermittently) at idle, and low throttle. could this be the cause?
    can i continue to drive it like this or should i park it? (my moms car has a bad starter and ive been letting her use my Daily)
  2. #2 Re: p0341 DTC ?
    Jun 2021
    Chats
    Bad sensor, wire or bad ignition control module.. reluctor rings never fail.. at least I've never heard of one bad
  1. P0341
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 07-21-2014, 09:22 AM
  2. P0341 help!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 10:53 AM
  3. P0141 p0341 p1351
    By jkwidener in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2011, 08:22 PM
  4. Error codes p0341 and po300
    By jessiinicole in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 04:34 PM
  5. P0341 OBD-2 code
    By icolex1 in forum General Tech Discussion
    Last Post: 02-22-2009, 10:19 PM
