Thread: Oil leak
Results 1 to 11 of 11
  1. #1 Oil leak
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    I have a98gtp the motor is an 01 I replaced all gaskets last year, everything from zzp, I have had no problems until I put full synthetic oil in last oil change about 3 weeks ago seems to be coming from passenger side it is filling up the motor mount I replaced the oil filter adapter faked 2 times..Any idea?
  2. #2 Re: Oil leak
    Well.. the front main is directly above the mount.
  3. #3 Re: Oil leak
    how about you de grease the engine and mount, then keep check ing on it after a day to see where the trail of oil is coming from.
    if its the crank seal it will leak and be seen pretty fast.
  4. #4 Re: Oil leak
    Topeka, ks
    That seal is easy to replace isn't it
  5. #5 Re: Oil leak
    Yank the balancer and it's right there
  6. #6 Re: Oil leak
    Topeka, ks
    Alright thanks guys
  7. #7 Re: Oil leak
    Dec 2013
    ohio
    I would think crank seal would throw oil around engine bay. I would check sending unit. It might run down the front of engine and be hard to see.
  8. #8 Re: Oil leak
    Quote Originally Posted by djudge1970 View Post
    It won't..
    Had one leak on me and unless you look on the ground you would never notice..
    I bet it's either the crank seal or sending unit both are easy enough to replace.
    04 Comp G.
  9. #9 Re: Oil leak
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    That is what I saw when my balancer seal was leaking. And it leaked rather fast for how small the leak looked. But yes, rather easy to replace.
  10. #10 Re: Oil leak
    and this is what a leaking oil pan looks like. yummy.
  11. #11 Re: Oil leak
    Aug 2011
    Michigan
    Lol dang, glad I don't have that problem yet xD
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
