Thread: Boost Questions! :)
Results 1 to 8 of 8
  1. #1 Boost Questions! :)
    Dec 2014
    Texas
    Howdy! ,
    I just had a few questions about this engine. Obviously specifically in the amazing pontiac gran prix.
    Here it goes.. How must boost can a stock engine take? Also if I wanted to increase boost how would I do that and what else on the engine, exhaust etc would you recommend me to "update" so I wouldn't blow the engine.
    Thank yall so much!
    Cheers -Alex
  2. #2 Re: Boost Questions! :)
    Mar 2014
    Tucson
    All good questions. Start here:
    http://www.grandprixforums.net/threa...00-Powered-Car!!
    That should get you going. Welcome to the forum! Lot's of knowledgeable guys here.
  3. #3 Re: Boost Questions! :)
    20+ psi.
    But seach function is your best friend for most of your answers.
  4. #4 Re: Boost Questions! :)
    hangover park IL
    ive had intake manifold pressure at 45psi on a stock motor with a new LIM gasket
    ~James~ Psychotic Gearhead
  5. #5 Re: Boost Questions! :)
    Kemmerer, Wyoming
    boost dosen't always make the most power. ignition timing advance is always there unlike boost.
  6. #6 Re: Boost Questions! :)
    Jul 2012
    Chicago
    Welcome.
    Do you have any power goals in mind?
    -Carl
  7. #7 Re: Boost Questions! :)
    Feb 2009
    flintnasty MI
    I've pressure tested most anything 3800 related to 60psi. Runor is the weakest part would be a plastic intake manifold at 100psi.
  8. #8 Re: Boost Questions! :)
    I remember when we ran 75 psi.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost gauge install questions!
    By des19 in forum General Tech Discussion
    Last Post: 08-14-2012, 11:33 PM
  3. boost gauge install questions!
    By des19 in forum General Grand Prix Discussion
    Last Post: 08-12-2012, 06:06 PM
  4. Replies: 17
    Last Post: 05-19-2012, 09:07 AM
  5. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
