Thread: coupling replacement
Results 1 to 13 of 13
04lss coupling replacement 11-19-2014, 02:24 PM
Speedy1973 Re: coupling replacement 11-19-2014, 02:27 PM
Scottydoggs Re: coupling replacement 11-19-2014, 02:28 PM
Speedy1973 Re: coupling replacement 11-19-2014, 02:29 PM
Flip97GTP Re: coupling replacement 11-19-2014, 06:07 PM
04lss Re: coupling replacement 11-19-2014, 02:31 PM
Scottydoggs Re: coupling replacement 11-19-2014, 02:35 PM
04lss Re: coupling replacement 11-19-2014, 02:37 PM
Scottydoggs Re: coupling replacement 11-19-2014, 02:42 PM
04lss Re: coupling replacement 11-20-2014, 07:23 AM
BillBoost37 Re: coupling replacement 11-20-2014, 07:28 AM
Flip97GTP Re: coupling replacement 11-20-2014, 09:06 AM
04lss Re: coupling replacement 11-21-2014, 08:52 PM
  1. #1 coupling replacement
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    The GTP needs a new supercharger coupling, I know i can pull the supercharger off, remove the snout and replace it that way. Im wondering if there is a way i can remove the snout without having to pull off everything.
    Im replacing the radiator this weekend so i figure while im at it i might as well do it.
  2. #2 Re: coupling replacement
    Apr 2012
    Bancroft. Ontario, Canada
    yeah, pull the belts, remove the alternator, and presto, you've got full access to all the snout bolts.... Would take you not even 5 min to get the alternator off....
  3. #3 Re: coupling replacement
    yup
  4. #4 Re: coupling replacement
    Apr 2012
    Scottydoggs beat me to it, was just about to add that vid to my post
  5. #5 Re: coupling replacement
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Quote Originally Posted by Speedy1973 View Post
    Don't you know Scotty burns rubber through here......Lmao!
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  6. #6 Re: coupling replacement
    Sep 2014
    Richmond Virginia
    Thanks! i didnt want to deal with the injectors and the UIM gasket. Im getting this black boat straightened out
  7. #7 Re: coupling replacement
    if you've not done the lim gaskets, your gonna deal with all that one day.....its not a big deal really. easy work.
  8. #8 Re: coupling replacement
    Sep 2014
    Richmond Virginia
    Ive had these engines down to the block before, id just rather take the easiest (and cheapest) route possible.
    I plan to replace all the gaskets when i add an intercooler and rockers.
    for now i just want to get it to the state of "reliable"
  9. #9 Re: coupling replacement
    got ya. wear latex gloves, ( the oil stinks, it will stay with your for days) have brake cleaner handy. i laid some rags down on the top of the timing cover cause whats left in the snout will leak all over. then spray it all down with brake cleaner, and wipe clean.
  10. #10 Re: coupling replacement
    Sep 2014
    Richmond Virginia
    Is there a snout gasket i need to buy?
  11. #11 Re: coupling replacement
    An anerobic sealant..and use very little
  12. #12 Re: coupling replacement
    May 2013
    Nice video! I am thinking about doing this as well, since I will have everything apart. I definitely need a new supercharger coupler. My supercharger makes a lot of noise and there is to much play on the pulley.
  13. #13 Re: coupling replacement
    Sep 2014
    Richmond Virginia
    Is there an alternative to the GM supercharger oil? something i can pick up at the local autoparts store
  1. Supercharger Coupling
    By jordan89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2013, 09:46 PM
  2. Where to buy rubber coupling for GTX hood.
    By kking89 in forum Introductions/Noob Questions
    Last Post: 07-23-2013, 03:07 PM
  3. Supercharger coupling question
    By CapnBreakAlot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2013, 10:31 PM
  4. Supercharger coupling life?
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2011, 10:08 AM
  5. Coupling Questions; upgrading speakers
    By trapper1306 in forum General Tech Discussion
    Last Post: 11-20-2010, 03:38 PM
