Thread: PCV valve ?s
Results 1 to 4 of 4
  1. #1 PCV valve ?s
    Sep 2014
    Las vegas
    I changed out the pcv valve in my 97 gtp today. I used the correct oem replacement part #CV892C. I noticed there was no rubber o ring anywhere on the outside of the valve or in the hole where the pcv valve goes into and I read on other threads that people do have an o-ring there. I believe the original pcv valve was still in there as it said AC Rochester on it and had the same part number as my new one (this must of been way back before it was ac delco?), so the o ring would be there if there ever was one. Is it possible 97's don't come with an o ring?
    My second ? is where can I find the gasket that sits right below the little black cover plate on top of the pcv valve? (the corners of mine ripped off a little on the outside edges of the 2 bolts upon removal but there is still a seal all around the pcv hole) I cant find it anywhere if someone has a part number that would be great.
  2. #2 Re: PCV valve ?s
    Sep 2014
    Las vegas
    Nevermind I re-examined it and upon closer inspection with a bright flashlight shining down the hole, the o-ring is in there its just pressed into the "reduction" part of the hole so well (where the pcv valve sits) and had oil residue on it that it was camouflaged pretty well. Now I just need to find a new gasket
  3. #3 Re: PCV valve ?s
    HUDSON
    For the PCV cover gasket, it might be easier to just get some gasket material and cut a couple of them for future reference.
  4. #4 Re: PCV valve ?s
    Mercer, Pa
    RTV works great
  1. aluminium valve covers, 90 lb ls6 valve springs for sale
    By SgtMarshal in forum For Sale - Parts
    Last Post: 09-04-2014, 04:30 PM
  2. 3.1 GP SE---EGR valve
    By ajmoore96 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-24-2014, 06:46 PM
  3. Stock intake valve versus 1.9 intake valve...worth it?!
    By slimguns in forum General Tech Discussion
    Last Post: 03-30-2013, 05:18 PM
  4. Replies: 26
    Last Post: 08-30-2012, 04:50 PM
  5. PCV Valve
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2010, 03:14 PM
