Hi guys,
I have a 2000 GTP with about 76000 miles on it. When I bought the car, I removed the supercharger belt because it was worn, and it kept slipping on the 3.4" pulley. I was also driving it after disconnecting the EGR since it was dirty and made my car jerk a lot while driving. That was until yesterday. Anyway, today, when I cleaned the EGR valve (Brakleen) and put on the new Goodyear Gatorback belt on the SC and started the car up:
1. The engine started but immediately died. This happened unless I kept my foot on the accelerator.
2. White smoke came out from the exhausts and also inside the engine bay. More smoke emerged from the exhausts than the engine bay.
There is another thing, however: I was going to remove the MAF and clean it, but I ended up just removing two bolts and all the plugs. I then replaced all the bolts and the plugs. Could this be a factor in this happening?
I know that white smoke is generally a sign of coolant entering the engine, but I just got my cooling system checked out 10 days ago, and replaced a leaking water elbow (if thats what it is), so I'm not sure if its the coolant, since the coolant level seems fine as well.
Thanks guys.
