Thread: Pulley Removal
Results 1 to 4 of 4
  1. #1 Pulley Removal
    Sep 2014
    Rhode Island
    So i was goingto swap out my pulley today, but i cant seem to be able yo remove this plastic pushpin that is covering the bolt. Does anyone know what I am talking about and how to remove it? Thanks.
  2. #2 Re: Pulley Removal
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I know exactly what you're talking about. I had trouble removing mine a couple months ago when i put on my MPS. I just eventually worked it out. I started using a flathead and eventually used a pair of garden shears. Yes i said garden shears. Once i could grab it with that I just cut off the tip and when the pulley came off the little bit left came off with it. That being said, a flathead and a pair of needle nose with a little WD-40 should work fine. Just be patient and stay with it.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: Pulley Removal
    warm up a phillips screwdriver with a lighter and shove it into the plastic piece and turn it out.
  4. #4 Re: Pulley Removal
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Once you get the edge of it up, you can also kinda unscrew it.Its not threaded itself,but the hole its in is.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  1. Pulley Removal Tool
    By GTPJIM in forum Wanted To Buy - Parts
    Last Post: 12-22-2013, 03:09 AM
  2. Pulley Removal Tool
    By HeavyChevyWes in forum Wanted To Buy - Parts
    Last Post: 06-20-2013, 03:08 PM
  3. Tensioner pulley removal
    By srspicer in forum General Tech Discussion
    Last Post: 05-08-2011, 03:36 PM
  4. Pulley bolt removal
    By Zinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 07:54 PM
