IAT in the LIM is quite common over here in Aus... especially on a2a intercooled setups.
Its usually around 85 degrees C when they start to not like timing anymore.
To be exact you guys pull timing at 104 degrees but only by 1 degree max timing being pulled all the way up to 176degree iat temp is only 2degrees.
Looks like if you do mount your iat else where in the lim you can easily setup this table to be more aggressive based on hotter outlet temps. Even with cold air intakes if the supercharger becomes heat soaked you're screwed until it has a moment to cool back down. That's just the nature of roots superchargers.
LOL. I just looked at the other BIN files i have. I was looking at the 97 bin I guess. LOL. 97s dont pull timing till 122*.
I'll reply more fully to everyone tomorrow but this one sticks out at me. If timing isn't pulled until 104 or 122* IAT - and that IAT is measured right behind the air filter - what is the "true" IAT post-blower? I dare say it's a whole lot higher.
A IAT sensor inside the LIM would allow for a more adaptive tune that could compensate for (1) the varying air intake temps which may be lowered by a CAI, (2) the heat added by the blower, and (3) any cooling effect that an intercooler has. Obviously when the latter heat soaks and IAT rises, the timing could naturally be yanked to prevent KR.
Someone take a screen shot of the IAT comp.
Last I checked, (2+ years ago) it won't work for post blower temps unless you're running an intercooler.
Yeah, I believe you'd have to scale it.
Maybe another tuner you can but you cant edit the axis temps, Youd have to figure it out or just blindly interpolate the right numbers in till you got the desired effect
You would have to scale the readings with a resistor or something.
Real dumb "data" provided in that post too.
The iat sensor is the slowest depry sensor ever created. Its flat out designed to fudge the temps over time and the 10 seconds you are ripping (stagnant) air on a dyno isnt going to instantly drop the temps as measured by that slow as molasses sensor.
The biggest difference is my motor having a ton of blow by
The newer card mafs have a really good iat even though it's integrated but since there cheap anyway 30-40 bucks. Yale could hack them up and use those iats
