Thread: Oil Leak
Results 1 to 17 of 17
  1. #1 Oil Leak
    So I noticed this last night after going for a cruise. I'm assuming that the silicone that I put in the corners of the lim gasket blew out in that corner.
  2. #2 Re: Oil Leak
    id check that front valve cover out. theres no pressure or oil up at the lim there.
  3. #3 Re: Oil Leak
    Probably a loose bolt if anything if it is the valve cover.
  4. #4 Re: Oil Leak
    clean it up and watch it if you dont find it wet under the lip of the valve cover.
  5. #5 Re: Oil Leak
    It does not appear to be leaking from the valve cover, there is oil all along the lower part of the lim and going down the back side of the engine as well. Its not a lot of oil so its just a slow leak, when I put the engine together I reused my old lim gaskets instead of the cheap plastic ones that came with the kit, and the end seals didn't hold up so well, looks like it didn't seal up like I was hoping it would. I'll just replace them when I do my cam.
  6. #6 Re: Oil Leak
    Never Never Land
    I'd say it's the end seal. I pulled the motor/trans out of my 4 door yesterday and found this exact same leak but on the opposite side. Apparently when I did my LIM gaskets and set the LIM in place I pushed the one edge out a little bit without realizing it. It's been leaking like a ***** and I could never figured out where it was coming from. I thought it was just the oil pan. But nope, it's the end seal for the LIM.
  7. #7 Re: Oil Leak
    Yeah new valley gaskets are only $10 from ZZP
  8. #8 Re: Oil Leak
    Never Never Land
    While we're on the subject of these. I've done three sets of LIM gaskets and both times the box has had 4 of these valley seals. One pair being blue and one being white IIRC. Anyone know what that's about?
  9. #9 Re: Oil Leak
    The kit I bought had blueish gray and red and black ones, the blueish gray ones don't seem to stay in place as well as the red and black ones. Zzp sells the red and black ones.
    Sent from A Galaxy Far Far Away........
  10. #10 Re: Oil Leak
    mine came with blue and orange, it had orange before, so i used orange again.
    clean that lim to block up, and smear some rtv on it. should stop it.
  11. #11 Re: Oil Leak
    Here's the answer to your question about extra seals.
    http://www.grandprixforums.net/threa...ghlight=design
    I'd triple check that it's oil not coolant first. The TB and or coolant turn around like to leak and look just like that.
    Only way you'd "blow out" a seal on the lifter valley is if your pcv was plugged.
    If you buy ZZP gaskets, best of luck. All the ones I've installed had inferior fitment.
  12. #12 Re: Oil Leak
    No its oil. The tb and coolant bypass gaskets are both new.
  13. #13 Re: Oil Leak
    I giggle a little when people say "new" New means absolutely nothing in my eyes. Dry.. now that's what I understand.
  14. #14 Re: Oil Leak
    lord knows ive installed new gasket's and had them leak in the past. sh it happens.
  15. #15 Re: Oil Leak
    No its not coolant, I took my finger wiped some if it off and it's just oil and dirt.
  16. #16 Re: Oil Leak
    get some brake cleaner, and a rag, clean that seam up, then rtv it. theres like no pressure inside there, so it should seal. if it keeps blowing oil, theres a pvc issue for sure.
  17. #17 Re: Oil Leak
    I forgot about this, I checked my valve covers and one of the bolts up in the top corner was loose. I snugged it up then I cleaned up the oil and its still dry there. I must have missed that one or something when I was putting them on.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
