Thread: rich fuel condition
Results 1 to 8 of 8
  1. #1 rich fuel condition
    Kemmerer, Wyoming
    do you guys think not running a catalytic converter would cause a rich fuel situation? I installed headers without the cat and I've been running rich for a while. 2001 GTP
  2. #2 Re: rich fuel condition
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Not having a cat shouldn't cause the change really but the full header combination may be a contributor. I have usually heard of guys being on the lean side after a header install vs. richer. But could be different for your case. Are you seeing it happen on a wideband?
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: rich fuel condition
    Kemmerer, Wyoming
    I dont have a wideband, I am assuming I am running rich because my aeroforce is showing 16.4 and -100. I thought those indicated a rich fuel condition.
  4. #4 Re: rich fuel condition
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    If you're seeing 16.4 you have a vacuum leak. Find it and fix it
  5. #5 Re: rich fuel condition
    Kemmerer, Wyoming
    if I blow compressed air through the evap system lines will that help isolate the vac leak?
  6. #6 Re: rich fuel condition
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by johntremell View Post
    I use a can of carb cleaner. If the engine revs up randomly when you spray, you've found your vac leak.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: rich fuel condition
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Possibly a vacuum leak, like stated above.
    Keep in mind, if you have any leaks in your headers, fresh air could get in before the o2 sensor, and throw off it's readings. The sensor would read extreme lean, and the PCM would dump fuel in an attempt to correct it.
    Also, you could have a bad O2 sensor. This was the case for me when I installed my headers. The o2 just did not like being moved from my old exhaust to my headers, and it went absolutely nuts with readings. I was going crazy looking for vacuum/header leaks, and in the end, replacing the upstream o2 sensor fixed the problem.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  8. #8 Re: rich fuel condition
    Kemmerer, Wyoming
    I had one exhaust leak that I fixed, I might have another leak to fix, but I also don't have a converter so that could be skewing my O2 sensor data and contributing to a rich condition. I'm going to check for vacuum leaks again today
  1. P0440 code and rich/ lean fuel
    By duswickware in forum General Grand Prix Discussion
    Last Post: 05-21-2014, 05:57 PM
  2. Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2014, 11:39 AM
  3. Cold thermostat causing rich condition?
    By EastBayGPSE in forum General Tech Discussion
    Last Post: 03-03-2014, 05:02 PM
  4. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
  5. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
