Thread: Valve cover question
Results 1 to 15 of 15
  1. #1 Valve cover question
    SE Level Member synfullj187's Avatar
    Aug 2014
    I'm going to be doing my gaskets ft & rear. This is a 99 gtp. my question is if I remove the left hand torque bar. When I take the mount off the engine. Will I need to mess with the tensioner or coolant elbows. I just want to be sure b4 I get in there. Thanks agine
  2. #2 Re: Valve cover question
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    SC belt tensioner and the cast iron bracket for the dog bone have to come off, the alternator bracket with the coolant elbows in it can be wiggled loose enough to get the valve cover off, but its a bit tricky.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Valve cover question
    Aug 2014
    Ok so just bkt and dog bone for the ft. Rite on thanks
  4. #4 Re: Valve cover question
    Aug 2014
    Do the fuel injectors leak oil if any o rings are bad?
  5. #5 Re: Valve cover question
    Aug 2013
    Sandy, UT
    Quote Originally Posted by synfullj187 View Post
    I'll just pretend you didn't ask that.
  6. #6 Re: Valve cover question
    May 2012
    Where winter never ends
    LOL
    2000 Regal - Winter Beater
  7. #7 Re: Valve cover question
    Aug 2014
    It's a legit question. Some injectors run oil by them. So don't be a dick
  8. #8 Re: Valve cover question
    Aug 2013
    Sandy, UT
    if the fuel injector orings are bad, upper side will leak fuel, lower side will cause a vacuum leak. Fuel injectors have nothing to do with oil nor does oil run anywhere near them. If you have an oil leak near the injectors look at your valve cover gaskets, valve cover gromets or lim gaskets.
  9. #9 Re: Valve cover question
    Aug 2014
    Ok dude, look obviously you don't read or u don't understand.
    1. If you read the above post you would have seen that I changed my cover gaskets & grommets
    2. If u knew anything about diesel engines like I do because that's what I do for a living everyday. I work on $300,000+ motor coaches. You would know that the injectors in most diesels use oil.
    3. This is my first car Ive owned other then all trucks. So I wasn't completely sure if the injectors on a car like this could leak any oil.
    and 4. People come on here to ask questions and get good knowledgeable answers. Not some lame a$$'es comment.
  10. #10 Re: Valve cover question
    Aug 2013
    Sandy, UT
    1. I gave you more things to look at than just VC Gaskets and gromets. Could be Lim gaskets, thats the only other thing that could leak oil in the area
    2. Good thing this isn't a diesel engine.
  11. #11 Re: Valve cover question
    Aug 2014
    Why didn't u say that in the first place? That's what I'm getting at.
    If it was a diesel it would be a lot better.
  12. #12 Re: Valve cover question
    Aug 2013
    Sandy, UT
    Quote Originally Posted by SnowTh1ef View Post
    I did say that.
  13. #13 Re: Valve cover question
    Aug 2014
    Try agine sir.
  14. #14 Re: Valve cover question
    Aug 2013
    Sandy, UT
    Like I said. Its not a diesel. And if you are such a wonderful mechanic, its pretty clear if you take a look at the injectors/rail and use common sense, and maybe even a quick google that gas engines only have fuel going through the injectors. Except for some very few direct inject engines. Which this is not.
  15. #15 Re: Valve cover question
    Aug 2014
    Lol wow its like arguing with a women . Dude if you just would have answered me like a mature adult. We wouldn't have been bickering like this in the first.
    Have a good day buddy
  1. Valve cover vacuum question??
    By krysp432 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2012, 05:26 AM
  2. Valve cover gasket replacement question.
    By Russosaur in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 04:38 PM
  3. Valve cover gasket question
    By Compg4me in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2012, 01:00 PM
  4. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  5. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
