Thread: 97 gtp l67 with Gen v m90 swap not building boost..
Results 1 to 4 of 4
  1. #1 97 gtp l67 with Gen v m90 swap not building boost..
    Sep 2014
    United States
    I have just preformed a Gen v m90 swap on my l67 I'm not sure why but it's not building boost. Dose anybody have any ideas?
  2. #2 Re: 97 gtp l67 with Gen v m90 swap not building boost..
    hangover park IL
    bbv is stuck open or someone blocked off the lower vac port instead of leaving it open to atmosphere or attached to a bbv solenoid
    ~James~ Psychotic Gearhead
  3. #3 Re: 97 gtp l67 with Gen v m90 swap not building boost..
    hangover park IL
    if you have a "ported" LIM dep on the shape at the bbv opening the gen5 evap passage sits over the intake so you could be pushing bost air into the crankcase
  4. #4 Re: 97 gtp l67 with Gen v m90 swap not building boost..
    GTP Level Member buickman104's Avatar
    NYC
    My brother in law's ssei just had the same issue when he did a gen 5 swap. The bypass plate in the supercharger was so gunked up with EGR carbon that the actuator wasn't able to close it all the way so he couldn't make boost. Had to take the blower off again and carb clean the coin until it was shinny again.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. Replies: 16
    Last Post: 01-09-2014, 10:55 PM
  2. Not building full boost
    By Wsmccoy in forum Turbo
    Last Post: 05-21-2012, 06:43 AM
  3. not building boost anymore?
    By fst in forum Turbo
    Last Post: 03-04-2011, 08:12 PM
  4. Attempting '97 Dual Climate Control Swap- Building shopping list
    By JBONE in forum General Tech Discussion
    Last Post: 09-17-2009, 11:20 AM
  5. Building Boost much faster
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 02:12 AM
