Thread: 130# springs to much for my application?
Results 1 to 20 of 33
  1. #1 130# springs to much for my application?
    Mar 2013
    Norfolk va
    OK guys I'm just trying to rule out all possibilities of knock..
    I have a 2003 Pontiac with nearly 113,000 miles on her. At about 36,000 I decided to mod my gtp a bit and at that time I bought an extreme energy cam with push rods 130# springs lifters rollmaster double roller timing chain. Tog headers high flow catback cold air intake..
    I was going to go even bigger but at that time fund's were a limiting factor..
    I've had more than one member here comment on the valve springs being more than I needed..
    Is it possible that the springs are to much spring and thus causing knock?
    Sent from my SCH-I535 using Tapatalk
  2. #2 Re: 130# springs to much for my application?
    Banned
    Jan 2013
    maryland
    Other mods?
    Sent from my LG-E980 using Tapatalk
  3. #3 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    3.4 pully dhp can tune..
  4. #4 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    I was planning to go even farther but then money got tight..
  5. #5 Re: 130# springs to much for my application?
    gardner,mass
    Doesnt really matter, you have a double roller. But with the mileage it might not be a bad idea to take a look at it for stretch.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: 130# springs to much for my application?
    May 2008
    Schuyler, NE
    No, your springs are not causing knock.
  7. #7 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    Hey thanks for the reply....
    Another question... Does anyone this if the tps sensor enhancer works?
  8. #8 Re: 130# springs to much for my application?
    Feb 2009
    flintnasty MI
    130 springs are minimum suggested size for most any cam.
  9. #9 Re: 130# springs to much for my application?
    May 2008
    Schuyler, NE
    Quote Originally Posted by grazin View Post
    Do you have a link? I don't know what you're talking about.
  10. #10 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    Sure I'll try and get it later.. Pfyc sells it . its a tps sensor enhancer .
  11. #11 Re: 130# springs to much for my application?
    May 2008
    Schuyler, NE
    I looked it up. It works, but it's a waste of money.
  12. #12 Re: 130# springs to much for my application?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Yeah... just floor it anyways. lol
    04 GTP -HAI, 1.9 rockers.
  13. #13 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    Well I'm going to take it easy till I get a good wideband tune.. Its my daily driver.. I already have enough problems with my Gto...
  14. #14 Re: 130# springs to much for my application?
    Aug 2013
    Sandy, UT
    My bonneville daily driver has the mods in my signature without a wideband tune. No issues. Driven it across the country.
  15. #15 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    Are u seeing 7 degrees of knock?
  16. #16 Re: 130# springs to much for my application?
    Aug 2013
    Sandy, UT
    ZERO
  17. #17 Re: 130# springs to much for my application?
    Aug 2013
    Sandy, UT
    If you are seeing that much knock you need to pulley up or find your mechanical issue.
  18. #18 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    Well considering I have a can full header back exhaust ported tb cold air intake with a 3.4 pulley , I honestly don't think I need to pulley up.. But I'm at a loss as to where the knock is coming from.. Only thing I can think is the canned tune is junk..
  19. #19 Re: 130# springs to much for my application?
    Aug 2013
    Sandy, UT
    Its not the tune. You have a mechanical issue. Headers are hitting somewhere knock sensors are bad. Dig around. A tune isn't going to cause 7*. Agreed that you shouldn't have knock on that setup, but you have something causing it. If you like your motor I'd pulley up until i found the issue or take the belt off. If you don't mind swapping the motor, then just keep praying you have 7* of false knock on a 3.4
  20. #20 Re: 130# springs to much for my application?
    Mar 2013
    Norfolk va
    Also.. When I pulled the plugs, they were really white meaning lean, meaning not good? Now knock sensors nor false knock wouldn't cause that would it?
    Also thanks for your input. Its much appreciated...
  1. Fuel prime question, not a normal application.
    By snookwheel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2013, 06:38 PM
  2. WTB: Cam for SC application
    By DOHCZ34 in forum Wanted To Buy - Parts
    Last Post: 09-29-2013, 07:52 PM
  3. vinyl application - milwaukee
    By Bio248 in forum Midwest
    Last Post: 05-04-2011, 12:27 AM
  4. Stoopid online application tests
    By Vegas_Matt in forum The Rant Forum
    Last Post: 04-05-2011, 10:49 PM
  5. transaxle application help needed here
    By overdrive in forum General Tech Discussion
    Last Post: 11-22-2010, 06:58 PM
