Thread: Gen v pcv
Results 1 to 11 of 11
  1. #1 Gen v pcv
    Aug 2013
    Kitimat, B.C.
    I have the nipple for the fresh air intake on the pcv capped and now have the breather in the oil cap. I ran about a month with it capped (done at time of swap) but no breather with no issues. I have the breather now so how important is that nipple?. I have no egr.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Gen v pcv
    Aug 2011
    colorado
    In stock configuration, that nipples serves the purpose of supplying fresh air from the intake to the PCV system. It connects to the intake between your maf sensor and throttle body. Are you intercooled or is your stock pcv sytem blocked somehow?
  3. #3 Re: Gen v pcv
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Maximum Gnarnage View Post
    its a gen v swap on a gen III in a fiero so I'm not sure if the pcv is working or not. I'm not intercooled but possible in the future.
  4. #4 Re: Gen v pcv
    GTP Level Member buickman104's Avatar
    NYC
    I had a issue that developed over time with my pcv system blocked and no valve cover breather where at idle the engine made a screech like a belt slipping as it sucked in through the front valve cover gasket (which was new). After I fixed the problem had to change the front valve cover gasket again as it was heavily leaking oil.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Gen v pcv
    Aug 2013
    Kitimat, B.C.
    I di have the breather but was wondering if I should find some way of making the pcv system work or just leave it the way I have it.
  6. #6 Re: Gen v pcv
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Drill and tap a hole in your tb after the throttle plate, but before the maf.Screw in a nipple,and run a vacuum hose between it and the pcv nipple on the sc.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  7. #7 Re: Gen v pcv
    Aug 2011
    colorado
    tweeder- what throttle body are you using?
    sounds like your stock pcv system should work fine and is definently better than a breather. basically, you need to uncap that nipple and route a hose from there to somewhere in your intake between maf and throttle body. your throttle body may have a nipple that serves this purpose in which case you could just attach it to that nipple.
  8. #8 Re: Gen v pcv
    Aug 2013
    Kitimat, B.C.
    I'm using the stock throttlebody with the gen III to gen v adapter plate.
  9. #9 Re: Gen v pcv
  10. #10 Re: Gen v pcv
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Don't run a breather. Make your PCV functional and do it the right way.
    Bad thing about the breather, it lets in unmetered air into the crankcase, scewing your LTFT's. Also, when I didn't have a functional PCV, everytime I took off the Gen V, there was oil/mildue sh*t all on the corner of the LIM, by the PCV inlet.
    Making your PCV functional is very simple.
    Tools needed:
    -Drill/Drill Bits
    -Tap & Die set
    -1/4 Nipple. (Got mine from Napa)
    Procedure:
    -Drill brass plug on the bottom of the stock Throttle Body
    -Tap with a 1/8 NPT
    -Screw in 1/4 Nipple
    -Run vacuum line from Nipple to PCV on Gen V
    No Bueno:
    Bueno:
  11. #11 Re: Gen v pcv
    Aug 2013
    Kitimat, B.C.
    Thanks for that Dan and Scott.
