Thread: Brake booster
Results 1 to 10 of 10
  1. #1 Brake booster
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    What are the symptoms of a bad break booster besides spongy breaks,is the cruise control connected to it since it runs off vacuum
  2. #2 Re: Brake booster
    Hard brake pedal. Cc shouldn't be effected
  3. #3 Re: Brake booster
    Jul 2010
    My brakes are spongy,can't figure cruise control out
  4. #4 Re: Brake booster
    a bad master is a soft pedal, or its got a leak and its loosing fluid.
    bad booster is a rock hard pedal, like the cars off and you pumped the brakes. if its soft car off pumping the pedal, its a bad master cylinder for sure, or its leaking.
  5. #5 Re: Brake booster
    Jul 2010
    Oh ok thanks,it still stops but takes time getting used to
  6. #6 Re: Brake booster
    id try bleed all the brakes, then if the pedal dont get firm again, change the master.
    look under it where it bolts to the booster, see if its wet under there. if so the master is bad. blown seal out the back side.
  7. #7 Re: Brake booster
    Jul 2010
    Oh ok I'll check it
  8. #8 Re: Brake booster
    MD
    Hi Scotty:
    I have the same issue, but it isn't wet under where the master and booster connect, although I see some rust/corrosion on the lower part of the booster drum. Fluid is disappearing somewhere, not leaking under wheels or anywhere under car, so I suspect it is leaking from the back of the master into the booster. Would I need to replace the booster too? What do I do if I discover a pool of brake fluid in the booster? Will it eventually get sucked out and burned in the exhaust?
    Thanks
  9. #9 Re: Brake booster
    Quote Originally Posted by jammy View Post
    Hi Scotty:
    Thanks
    dont think it can leak back into the booster, its sealed, only a rod pushes through it into the master. masters do go bad and not leak. but you must have a leak if the fluid keeps dropping, unless you did brakes 3 years ago and have not checked the level since and just looked and its low, thats normal. pads wear and more fluid is stored in the calipers.
  10. #10 Re: Brake booster
    MD
    Thanks, Scotty. I checked again, and got a friend to pump the pedal while I took a closer look. Sure enough I have a leak in the line(s). I'm going to create a new thread since mine is no longer a master/booster issue. PLease look for it and comment. I always appreciate your help.
    Jammy
  1. Brake Booster
    By grandamle91 in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2014, 12:15 PM
  2. Bad brake booster?
    By Pure2sin in forum General Tech Discussion
    Last Post: 01-27-2012, 11:58 PM
  3. Brake booster line
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2011, 10:57 PM
  4. 2001 GTP Brake Booster
    By Greg66 in forum Introductions/Noob Questions
    Last Post: 10-28-2009, 08:37 AM
  5. Brake Booster? Who has changed one?
    By sra_chipmunk in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2008, 07:24 PM
