Thread: valve on bottom of supercharger.
Results 1 to 6 of 6
  1. #1 valve on bottom of supercharger.
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey. I was wondering if that valve is the same from gen 3 to gen v. Because I have a Gen V without that. Was wondering if I can take it from my gen 3 when I do my swap
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: valve on bottom of supercharger.
    GTP Level Member buickman104's Avatar
    NYC
    do you mean the boost bypass valve?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: valve on bottom of supercharger.
    Orland Park, IL
    Yes. That's what i thought it was. But i didn't want to say the wrong thing
  4. #4 Re: valve on bottom of supercharger.
    That's a really good question. I'd need to measure...
  5. #5 Re: valve on bottom of supercharger.
    Mercer, Pa
    They are the same
  6. #6 Re: valve on bottom of supercharger.
    Orland Park, IL
    Sweet! Thank you!
  1. Supercharger bypass valve trouble
    By ED503 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2013, 10:47 PM
  2. slits in bottom of supercharger. how to close them
    By msukid68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2012, 05:44 PM
  3. supercharger blow off valve?
    By 2story in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 06:24 PM
  4. PCV Valve and Retainer for Gen V Supercharger
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 07:53 AM
  5. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
