Thread: differences in superchargers really need help!
Results 1 to 8 of 8
  1. #1 differences in superchargers really need help!
    Jul 2014
    Virginia
    I bought a 2001 gtp supercharger that was ported for my 1997... well there is no vacuum solenoid on it is this a big problem will the car even run?
  2. #2 Re: differences in superchargers really need help!
    That vacuum tree?
  3. #3 Re: differences in superchargers really need help!
    Jul 2014
    Virginia
    Yes that and the solenoid arent there on the new blower.
  4. #4 Re: differences in superchargers really need help!
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Mind attaching a pic? Then we can make sure we're talking about the right parts
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  5. #5 Re: differences in superchargers really need help!
    Jul 2014
    Virginia
    I can for sure text you one the solenoid can still bolt on the thing that goes into the m90 can no longer be bolted in the holes are filled and the spring on the lever is removed.
  6. #6 Re: differences in superchargers really need help!
    you run 98 vac line routing. google it.
    only 97 had that vac tree on the blower, car will run with out it change the way the lines run, thats all.
    the bbv maybe f'ed up and needs to be replaced.
    host your pics on photo bucket, then link them here. so we all can see em.
  7. #7 Re: differences in superchargers really need help!
    hangover park IL
    wait someone filled the boost bypass valve bolt holes and the actuator arm?
    sounds like it may have been used as an (empty) turbo intake setup...
    ~James~ Psychotic Gearhead
  8. #8 Re: differences in superchargers really need help!
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    ^ 97 blower vacuum line routing.
    ^ 98+ blower vacuum line routing.
    ^ Is this what is missing? The Boost Bypass Actuator? Are you saying where this actuator arm goes into thw supercharger housing is blocked off?
  1. Superchargers
    By TJeno in forum General Grand Prix Discussion
    Last Post: 05-30-2014, 06:52 AM
  2. Superchargers and PartsLady
    By Logan541 in forum General Tech Discussion
    Last Post: 04-01-2013, 08:14 PM
  3. Superchargers
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 01-18-2011, 12:48 PM
  4. New to superchargers
    By High Rolling GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2009, 11:35 AM
