Thread: only 80-89% at WOT
Results 21 to 40 of 70
  1. #21 Re: only 80-89% at WOT
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    yea I guess ill do that before buying a new TPS(yes from JET)
  2. #22 Re: only 80-89% at WOT
    GrandPrix Junkie
    Mar 2012
    NC
    Sounds like a plan. Also, the WOT TPS voltage is typically around 4.5-4.7V (or 90-94% throttle open) from what I've seen. Others may have seen higher.
  3. #23 Re: only 80-89% at WOT
    Mar 2014
    Canada
    ok im gonna get it looked at from the mechanic at the speed shop I work at... trying to figure things out on my own... good day for him to roll my fenders and put the new exhaust on too I guess
    thanks for trying to throw some help at me!
  4. #24 Re: only 80-89% at WOT
    GrandPrix Junkie
    Mar 2012
    NC
    No problem. Good luck.
  5. #25 Re: only 80-89% at WOT
    0.40 V is 0% and 4.0 V is 100%.
    Everything else doesn't matter.
    Rotate the sensor so that you get below 0.40 V at idle, and above 4.0 V at WOT. Check the ground, and check for 5V at the connector.
    The other area of concern is, does this device actually read the value correctly?
    So in short, check for voltage, not TPS.
    Hah, good thing I remembered this little fun thing: http://www.hptuners.com/forum/showth...2069#post32069
    In short, it's likely an issue with your data logger not interpreting the PCM data correctly.
  6. #26 Re: only 80-89% at WOT
    GrandPrix Junkie
    Mar 2012
    NC
    His gizmo does not read PCM data...it merely intercepts it via splices.
  7. #27 Re: only 80-89% at WOT
    No wonder he's only seeing 88%, to GM, 4.0 V is 100%.
  8. #28 Re: only 80-89% at WOT
    Donating Users Uno99's Avatar
    Appleton, Wi
    So is this thing just tricking his PCM by sending different frequency to his MAP and MAF? Via some sort of resistor inside the module he spliced in?
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  9. #29 Re: only 80-89% at WOT
    It doesn't matter what it does, it won't make any more power. You don't make more power with a PCM tune on a 3800. You just play with transmission settings, correct fuel system when you add bigger injectors and that sort of thing.
  10. #30 Re: only 80-89% at WOT
    Mar 2014
    Canada
    how do I test the TPS voltage? where do I put the pins?
  11. #31 Re: only 80-89% at WOT
    DMM on the pins, proper scan tool etc.
    Pinout might be on the sensor itself, but it's pretty easy to figure out.
    Check voltage from ground to each pin. One will be 0V (Ground), one will be 5V (5V supply) and another will be a varying value depending on TPS (TPS signal). Engine doesn't need to be started either. Might be ideal to turn the key to on, and leave the engine off. That way you can test WOT right there in the driveway without bouncing the engine off the rev limiter.
  12. #32 Re: only 80-89% at WOT
    Appleton, Wi
    That's not what I asked or care about........... Im just interested in what is inside.
    Also so your telling me that if I go out and do a good MAF tune or SD tune with my HPT add some timing im not gonna make more power from a PCM tune??
  13. #33 Re: only 80-89% at WOT
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Honesty, alot of those splice in things like that ive seen just trick the pcm into seeing the iat colder than it really is using a resistor.Bumps the timing up, which isn't ideal.lol.That may not be one of them,but it does sound like it.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  14. #34 Re: only 80-89% at WOT
    Appleton, Wi
    Thats what I was kinda thinking. I remember back in my LS1 days SLP had a 85mm MAF that did something like that. Tricked the pcm some how and everyone flamed on it. I'm surprised Jet would put there name on that.
    I would really like to see the insides of that thing. I bet there ain't much to .
  15. #35 Re: only 80-89% at WOT
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Uno99 View Post
    This is exactly what it does. They work fine on the 3800 Series I, just not on anything with ODBII. Although the JET modules I remember just snapped in between your PCM connectors to modify the signals, no splicing.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  16. #36 Re: only 80-89% at WOT
    GrandPrix Junkie
    Mar 2012
    NC
    Quote Originally Posted by industrialfish View Post
    They actually still sell those too. I'm not sure what exactly they try to do to the signals, but if I ever find one (for free obviously) I'll plug it into my Z28 just to see the sensor values affected on the scan tool.
  17. #37 Re: only 80-89% at WOT
    Mar 2014
    Canada
    Thanks for the info guys.
    Are there any write up links for doing a TPS relearn?
    also need a write up for the EGR delete.
  18. #38 Re: only 80-89% at WOT
    Feb 2009
    flintnasty MI
    Google gm tps relearn. You basically floor it turn key on turn key off, off pedal turn key on turn key off. Repeat 4 times
  19. #39 Re: only 80-89% at WOT
    Mar 2014
    Canada
    ok looking into it now. thanks
  20. #40 Re: only 80-89% at WOT
    Mar 2014
    Canada
    TPS relearn didn't work, so Im guessing its the unit not reading proper... no biggy as that's not what I wanted it for...
    another question, when I do the EGR delete do I have to take the entire thing out or do I just take off the top part and put the block off plate there leaving all the hoses and what not hooked up?
