Thread: Injectors
Results 1 to 20 of 28
  1. #1 Injectors
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    http://m.ebay.com/itm/160869870175
    Has anyone run these injectors in our cars?
    I am wondering, do these have the same spray pattern as the injectors from the 97 - 03 GTP's?
    Also, I believe they require spacers if I'm not mistaken. Can anyone confirm that?
  2. #2 Re: Injectors
    Donating Users Uno99's Avatar
    Appleton, Wi
    Interesting find hopefully someone has some info on these :-)
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  3. #3 Re: Injectors
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    holy F*** thats half the price of 1 oem one from gm!!!
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  4. #4 Re: Injectors
    Aug 2011
    Michigan
    Lol right. Thats why I am interested to know. I think a guy on here ran them but I didn't see if they were the same spray pattern or not. But I think I remember reading they weren't long enough and required spacers I do believe
  5. #5 Re: Injectors
    Jun 2014
    Ontario Canada
    either way thats cheap as ****, gm wants 160 a piece, i nearly dropped onto the floor, and thats at my price, i work at nissan so i cost + 20%
  6. #6 Re: Injectors
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    those are the shortys. you would need the machined adapters to use them.
  7. #7 Re: Injectors
    Aug 2011
    Michigan
    I see. Just looking for an alternative to the ZZP brand 42.5's because of the cost o.O
  8. #8 Re: Injectors
    First question is: Are they knockoffs?
  9. #9 Re: Injectors
    Aug 2011
    Michigan
    It says they are OEM Delphi High flow injectors for GM 6.0L engines
  10. #10 Re: Injectors
    Ebay also tells me this is legit:
    http://www.ebay.com/itm/Volvo-Vida-D..._Tools&vxp=mtr
    But the real one is worth ten times that.
  11. #11 Re: Injectors
    Aug 2011
    Michigan
    Interesting. I probably won't get these injectors anyways simply because of the machined spacers required as I assume they would probably out the total cost close to what the known to work 42.5# ZZP injectors cost
  12. #12 Re: Injectors
    Jul 2011
    CT
    i see FS posts often for used #42 injectors from $100-150. keep your eye on the classifieds.
  13. #13 Re: Injectors
    Aug 2011
    Michigan
    I've had my eyes on the fs section for like 2 weeks now, I'm all over that ;P
  14. #14 Re: Injectors
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I think it's those overkill uses.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  15. #15 Re: Injectors
    Aug 2011
    Michigan
    Overkill may use the ones I posted?
  16. #16 Re: Injectors
    Jul 2011
    CT
  17. #17 Re: Injectors
    Aug 2011
    Michigan
    I thought there was discussion on the Mustang injectors being the incorrect spray pattern?
  18. #18 Re: Injectors
    Jul 2011
    CT
    i missed that discussion apparently. But from what i can tell, these look to be identical to the ones zzp sells.
  19. #19 Re: Injectors
    Aug 2011
    Michigan
    Hmmm
  20. #20 Re: Injectors
    Jul 2011
    CT
    im not sure what your goals are, but if you ever intend to run e85 i would skip the 42s all together and get #60s.
  1. do i need to get injectors?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2010, 05:48 PM
  2. How are the 42# injectors?
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2010, 08:00 PM
