Thread: ZZP throttle body turndown?
Results 1 to 20 of 28
  1. #1 ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    We all know TB spacers are useless for most people, but does the ZZP turndown have any negative effects? Right now my 9" cone is clamped directly to the MAF. I don't plan on ever getting an intercooler, but I like how the turndown looked on Smuts' car and it would put my intake closer to cooler are at the fender wall. I wouldn't bother if it'll reduce the flow too much though.
    7"
  2. #2 Re: ZZP throttle body turndown?
    Your filter probably wouldn't fit then it'll hit the spot where the pcm sits
  3. #3 Re: ZZP throttle body turndown?
    hangover park IL
    yeah zzp needs to take at least 5* out of the turndown...it bends down too far on the 04+ tb pattern units
    ~James~ Psychotic Gearhead
  4. #4 Re: ZZP throttle body turndown?
    hangover park IL
    go **** yerself pizzaboy
  5. #5 Re: ZZP throttle body turndown?
    hangover park IL
    lol my new camaro on the F body forums...do you even drive bro?
  6. #6 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    That's a good point, without the extra height from an intercooler, I may not have clearance for the filter.
    7"
  7. #7 Re: ZZP throttle body turndown?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Ever considered using PVC? I can only think with the added bit for the MAF it might be too long and hit things depending on the bend. Plus depending on the couper you get it can look kinda weird.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    Nah, going to try to stay away from PVC on this car... for now. And yeah, adding a bend between the MAF and filter looks odd to me. Sticks out too far then turns and stick out some more. At that point I'd just got full CAI
    7"
  9. #9 Re: ZZP throttle body turndown?
    Apr 2012
    Dayton, OH
    Maybe you can find a peice of pipe bent at like whatever desired angle you need. You know like those chromed up ones you see people have. Probably kinda expensive but looks better than PVC.
    2012 F150 STX
  10. #10 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by industrialfish View Post
    Although, now my engine is lifted .75 from Vinnies spacers. Screw it, I think I'll go for it. Can always resell it.
    7"
  11. #11 Re: ZZP throttle body turndown?
    Mercer, Pa
    The turndown is only 72mm (aprox) ID. so the turn down is a restriction for your throttle body.
  12. #12 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    Hm... I thought L32 WAS 72mm
    7"
  13. #13 Re: ZZP throttle body turndown?
    hangover park IL
    its 75mm but its effectively 70 with the way the blade and airshelf is designed to allow for small airflow correction via the stepper motor.
    welcome to the compromise of not having a pintle type IAC and a 3$ cable....
  14. #14 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    Yeah I just went and measured it. 76mm on the MAF side, 75mm on the SC side.
    7"
  15. #15 Re: ZZP throttle body turndown?
    Feb 2009
    flintnasty MI
    Turndown for what?
  16. #16 Re: ZZP throttle body turndown?
    Mercer, Pa
    The inlet turn down is approx. 70mm.
    Turbocharged400sbc Where did the effective 70mm come from? Is that your guess or is that from some where?
  17. #17 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    Turndown for what?
    http://i1130.photobucket.com/albums/...psnqhmzzum.jpg
    See the black bend thing between the supercharger and the throttle body?
    EDIT: Yes, I completely missed the joke.
    7"
  18. #18 Re: ZZP throttle body turndown?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by sseilmnop View Post
    Man... Nowhere on ZZPs site do they say what size it it, but they reference the Gen 5 multiple times which leads me to assume it was the same size. That seems kinda shady.
    7"
  19. #19 Re: ZZP throttle body turndown?
    Mercer, Pa
    I measured it before and it is 70mm. No way the stock
    TB is effective 70mm. That is almost 15 percent smaller than 75mm.
  20. #20 Re: ZZP throttle body turndown?
    hangover park IL
    well to start there is a 10 millimeter thick shaft running through the middle of the smallest part of the bore...
    then onthe DBW there is also the airflow shelf that is riveted to the blade so that at throttle openings less than 15 pct, only one half of the throttle blade is effectively changing the airflow volume.
    even then it does not allow for very fine changes in idle control...it works well enough though
  1. Detaching and Reattaching Throttle Cables to L67 Throttle Body
    By komrad36 in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2017, 12:09 PM
