Thread: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
Results 1 to 12 of 12
  1. #1 Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Banned
    Jan 2013
    maryland
    Gonna extend my 02 sensor and wanted to know the best way instead of buying a zzp extension the last time I spliced to extend but which methods would you guys do? also my o2 I grabbed is a aftermarket it fits on my SD headers but are they just as good as stock 02 sensors? aftermarket pic is below thanks
    Sent from my LG-E980 using Tapatalk
  2. #2 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Oct 2011
    Toledo, OH
    I just had to extend my new Denso front plug for my SD's. Your best bet is to extend the car side harness since it is copper and you can solder to it. If you've already cut your plug off your O2 sensor, you can use crimps, no soldering because they are stainless steel wires.
    I ended up cutting the old wire at the sensor, and new wire at the plug and crimping them together. Only ran the car a little while to get it up to temps to test the headers, but it didn't throw a code.
    Your aftermarket plug only has 3 wires? Factory has 4, but I think there is 2 ground wires.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  3. #3 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Banned
    Jan 2013
    maryland
    I'm not by the car right now I'll check but I'm pretty sure it has 4 its from prime choice off eBay
  4. #4 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Florida
    That's the same o2 sensor I'm using on my car and the wire on mine was just long enough to reach the harness. Didn't need to splice or extend however it has been throwing codes ever since and car runs like it has a mis at times on top of weird fluctuating gas mileage.
  5. #5 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by dmahlikGT View Post
    So basically this o2 is trash?did this happen when you installed it happen?
  6. #6 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Florida
    yup when i installed it. i would just snag one off rockauto.com
  7. #7 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Banned
    Jan 2013
    maryland
    How did the car run? Bad? Bad idle starting my car tomorrow just did a rebuild on my motor and tha y should be the least of my worries
  8. #8 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Do not cut the sensor harness for the o2 sensor. http://forums.corvetteforum.com/1567396963-post4.html
    You can also make your own extension harness if you want, just swipe the connectors off a car in the pick n pull.
  9. #9 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Mar 2012
    South Beloit, IL
    dmah, you said your car ran like it had a misfire. Was that once it went into closed loop, or was that even in open loop? Just checking, cause I spliced my wires at the sensor (stupid idea) and it has a slight misfire at idle.
  10. #10 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Slick2500 View Post
    The problem isn't splicing them, it's soldering them.
    7"
  11. #11 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    exactly, the o2 pig tail off the o2 has a stainless steel wire, it wont solder, but the cars harness is all copper, and you can make that plug longer no problem as they are all copper wires.
  12. #12 Re: Gonna Extend my Front 02 sensor thoughts? aftermarket 02?
    Florida
    Yea its basically when I'm cruising and car is warmed up. Happens about 80% of the time when I drive. Its not a misfire but feels like one. Got my codes scanned and all of them point to the upstream o2 sensor. I'm going to get another one soon.
  1. Replies: 9
    Last Post: 12-19-2013, 07:08 AM
  2. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  3. WTB: SD Front Air Dam OR Any Aftermarket Hood
    By Vile in forum Wanted To Buy - Parts
    Last Post: 02-17-2012, 08:41 PM
  4. aftermarket front bumper options?
    By Cobras 98 Prix in forum Visual/Body Modifications
    Last Post: 02-10-2012, 09:29 PM
  5. 04+ aftermarket front sway bar
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2008, 03:54 PM
