Thread: bad headgaskets from overheating
Results 1 to 12 of 12
  1. #1 bad headgaskets from overheating
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    So long story short my l67 overheated due to a belt break, a few weeks later the head gaskets went. So I basically just want to know if its worth putting new head gaskets on or do you think there is too much damage like cracked or warped heads. So am i better off buying a new engine if so where is the best place to find a good engine.
  2. #2 Re: bad headgaskets from overheating
    Aug 2013
    arlington, tx
    I have an 04 na and my head gaskets failed. I put new gaskets and had a little but of work done on the heads and it's been fine ever since. Definitely cheaper than buying a new motor and not a real hard job to do yourself.
  3. #3 Re: bad headgaskets from overheating
    Jun 2013
    brookville,IN
    what did you have done to the heads, were they milled
  4. #4 Re: bad headgaskets from overheating
    Aug 2013
    arlington, tx
    Yea. Milled, magnafluxed and got a valve job done.
  5. #5 Re: bad headgaskets from overheating
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I bought my car with an apparently overheated engine and bad headgaskets. Was drinking coolant, missing on Cyl 3 and 5. (HG was burnt between the both on a coolant hole, exhaust valves were burnt aswell.)
    15k later, new gaskets all over, XP Cam and new lifters. Had the heads milled, magnafluxed, bad valves replaced and the other had a job done.
    Still drives fine today with the mods.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  6. #6 Re: bad headgaskets from overheating
    Jun 2013
    brookville,IN
    Sounds good i guess I'll be doing the same, do I need to get a thicker gasket if the heads are milled so i don't raise the compresssion?
  7. #7 Re: bad headgaskets from overheating
    Depends on how much they take off, but I doubt they would take enough off to make that big of a difference.
  8. #8 Re: bad headgaskets from overheating
    Jun 2013
    brookville,IN
    Should I replace the lifters too, I don't plan on doing a cam I'll just keep the high ratio rockers?
  9. #9 Re: bad headgaskets from overheating
    No need to replace the lifters unless any of them need replacing.
    04 Comp G.
  10. #10 Re: bad headgaskets from overheating
    Jun 2013
    brookville,IN
    thx for all the replys guys you have no idea how much i appreciate it.
    I have another question. If i have them port and put new valves in would it make any more power I dont plan on running a cam just the 1:8 rockers that are on it. If not is there anything worth doing while the heads are off polishing maybe?
    I also have an intercooler to go on and 3.0 pulley+e85 but i dont have any more plans for mods.
  11. #11 Re: bad headgaskets from overheating
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Not saying a proper valve job wouldn't help.....because it will, but, unless you open up the intake and exhaust ports....you may not notice it.
    Official GPF Red Neck
  12. #12 Re: bad headgaskets from overheating
    Jun 2013
    brookville,IN
    So are you saying I will notice bigger valves such as the si valves that zzp sells
  1. any hop-ups while engine is torn apart and replacing headgaskets?
    By 05silverado4x4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-24-2012, 07:02 PM
  2. Coolant issue....headgaskets?
    By 98L36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2011, 11:55 AM
  3. Which Headgaskets?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 11:56 AM
  4. L36 headgaskets....old age..pics
    By UR LOSN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2008, 08:46 AM
