Thread: Coolant Elbow(s?) on 98 GTP
Results 1 to 5 of 5
Threaded View
  1. #1 Coolant Elbow(s?) on 98 GTP
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    hello, I apoligize for not taking the time to introduce myself, but I have a problem that's driving me up the wall and through the ceiling.
    I'm doing the intake gaskets and lifters on my gtp, and I simply cannot remove the tensioner/alternator bracket. I've gotten the three bolts, and I bought new elbows, so I just cut the one going to the lim in half. however, it just pivots around on something i assume to the the second elbow, except where the elbow is supposed to be, it looks like it just disappears into the waterpump housing. I've done at least 4 hours of research and cant find anything related to my problem. I would just replace the elbow I cut out and not worry about taking the bracket completely off, but I'm not interested in having to tear it down again just because of something as stupid/simple as this. I should mention it is quite cold in the garage due to winter, which makes everything 100x more resistant/brittle than usual.
    I cannot locate the camera, otherwise I'd have taken a picture of the problem area. I look forward to participating in the community more when I get through with this mess
    EDIT: heres a stock photo with the problem area circled
    EDIT2: I have the 97-style mount with the cast fitting instead of the elbow, any tips/tricks to getting it out? I've tried wiggling, gently tapping and pulling with no avail
  1. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  2. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  3. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
  4. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
  5. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
