Thread: Throttle dip while cruising.
Results 1 to 3 of 3
  1. #1 Throttle dip while cruising.
    gardner,mass
    Ok so ive been having this intermittent issue while cruising, ill have my foot steadt on the throttle (say 2000-2500 rpm) and all of a sudden my rpms will dip slightly then be fine. Ive also been having and issue with my trans slipping in all gears. Seemed like it was only when cold but it is doing it while warm. Both issue have been progressivly getting worse. When the trans slips if i rev it into gear then it seems to drive fine after that initial slip. But if i baby it it will continue to slip untill i drive it a bit and it warms up. Idk if the issues have anything to do with each other. I was thinking possibly maf sensor but tried cleaning and driving unplugged and still slipping. What about a throttle pos sensor? Is it possible the trans is acting funny because of?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Throttle dip while cruising.
    why oh why do i remember this crap from the 80's? lol
    http://www.youtube.com/watch?v=-B8Vh...layer_embedded
  3. #3 Re: Throttle dip while cruising.
    gardner,mass
    Well so a little update. Now the car wont move in drive but does is manual but is having issues shifting when i try to and slips a little bit but does move whereas i cant go anywhere in drive. It eventually shift into 2nd and 3rd but is delayed. Checked for codes and nothing. Reset pcm and nothing. I checked the fluid and it was a little high and i drained some out. Has reverse fine. Befor it died completely it would slip in all gears not just first in manual and drive.
  1. 2006 GP cruising along and then stalls
    By juicestain100 in forum General Tech Discussion
    Last Post: 10-24-2014, 05:50 AM
  2. RPMs bouncing when cruising
    By nukkinfuttz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2012, 07:05 AM
  3. Highway Cruising
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2009, 03:31 PM
  4. kr at cruising???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:20 AM
  5. Few kills just cruising around..
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 11-02-2008, 10:20 PM
