Thread: P0300 and P0305 Codes
Results 1 to 2 of 2
  1. #1 P0300 and P0305 Codes
    Jul 2012
    Bad Axe, MI
    Ok. I have an 06 Grand Prix GT Supercharged with 55,000 miles on her. I just bought the car and I'm geting these two codes randomly. The p0305 set's quite often but I get the p0300 sometimes. The car stumbles hard when under heavy load ans has a somewhat rough idle. The porcelain on the #5 plug was cracked so I changed the plug but the issue came back. I've swapped coil packs around but the issue doesn't move.
    I've read a lot of info on here and most seem to point to a plugged cat but I'd like some more input before I just buy a new cat for it. Any advice welcome.....
  2. #2 Re: P0300 and P0305 Codes
    St. Louis
    Might be time to do all the plugs and wires. And be sure to install either the stock irridium plugs, or copper only. NO PLATINUM PLUGS!! Also, you are running at least 91 octane in it, right?
    Could also check the connection to the ICM (the part the coils bolt to) and check your grounds. Also check to be sure that your plug wires are in the correct order. It happens often and depending on which wires are switched around the car can run just fine except for a miss.
  1. P0305 code
    By Cibargar69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2014, 01:46 AM
  2. GT engine trouble codes p0300 and p0108
    By Coyote86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2013, 02:12 PM
  3. I stumped. Idles and runs ruff. Codes P0300 P0135. New Cat Last year. Help
    By siwittschulte in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2012, 09:09 AM
  4. CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2012, 11:01 AM
  5. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
