Thread: full size intercooler help I need a diagram
Results 1 to 7 of 7
  1. #1 full size intercooler help I need a diagram
    GT Level Member Hardonyomom's Avatar
    aurora
    Ok long story short. I took my intercooler apart on accident and i still have the bottom of it attached to the LIM, i have the little radiator in the top one still that i put RTV around to make it seal. Is there a diagram of where to put rtv to put it back together or just rtv the crap out of it instead? Yes i searched. Please help I am trying to get the top of the intercooler onto the bottom with a tight seal. I dont know where to put the rtv at.
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: full size intercooler help I need a diagram
    aurora
    After looking at this again and again. I realize that the there was black rtv all around the inside and outside edges. I think i need to ditch the orange rtv and use grey on the bottom where it sits in and on the edges?
    Or am i better off just taking the whole thing apart off of the LIM and restarting? problem is i dont know how to properly reseal this. Hopefully someone will chime in
  3. #3 Re: full size intercooler help I need a diagram
    Remove.. clean all surfaces ... clean....
    Add rtv and or a paper gasket and torque at the same time you are assembling it. You said in chat you let the rtv dry overnight because you didn't have a torque wrench. That one thing was likely your issue.
  4. #4 Re: full size intercooler help I need a diagram
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    here's a pro tip. you can smooth rtv with an ice cube and it wont stick to it.
  5. #5 Re: full size intercooler help I need a diagram
    Or..a gloved finger
  6. #6 Re: full size intercooler help I need a diagram
    Mercer, Pa
  7. #7 Re: full size intercooler help I need a diagram
    Mercer, Pa
    Pink arrow is a PCV passage. Don't block it or the PCV won't work.
  1. NEW Gen V Full Size Intercooler kit...
    By rodguezsciii in forum For Sale - Parts
    Last Post: 02-14-2016, 04:04 PM
  2. ZZP Stage 2 Full size Intercooler
    By 05impalaSS in forum For Sale - Parts
    Last Post: 10-01-2013, 07:25 PM
  3. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  4. Full Size Intercooler Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:38 AM
