Thread: What does this do? (Ground sensor?)
Results 1 to 3 of 3
  1. #1 What does this do? (Ground sensor?)
    SE Level Member Daven's Avatar
    Apr 2014
    Saskatchewan, Canada
    These were both on my ground. Could somebody fill me in on what these are for? The voltage meter?
    Using Tapatalk
  2. #2 Re: What does this do? (Ground sensor?)
    Mar 2012
    South Beloit, IL
    Just taking a guess here, it looks like the wire that goes to the ring connector that gets bolted to your head. You have a newer GP so I am not sure, but if you check under your ICM where the alternator support bar bolts down, it may be there.
  3. #3 Re: What does this do? (Ground sensor?)
    Apr 2014
    I think, but I am not sure, that it goes into the fuse box that's right there. It goes underneath and everything is so cramped that I can't see a thing lol
    Using Tapatalk
  1. Where to ground amp?
    By TJZane21 in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2013, 01:32 AM
  2. bad ground ??
    By GTPgurl in forum General Tech Discussion
    Last Post: 03-04-2011, 09:19 AM
  3. Amp Ground
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:14 PM
  4. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
