Thread: Engine swap
Results 1 to 19 of 19
  1. #1 Engine swap
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    Doing my engine swap this weekend. Going from a series 2 to series 3. Any tips? Any parts that's gonna give me a hard time? And will I have to do a relearn on my PCM? I have a 2001 gtp
    2001 sliver gtp her name is Reagan
  2. #2 Re: Engine swap
    Assuming its a L32 replacing your L67, they is nothing really different at all.
    Just swap the parts over from your old motor and it will run as normal.
  3. #3 Re: Engine swap
    You should do a crank relearn. Beyond that.. no .. the pcm will/should adapt to the change in airflow etc
  4. #4 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    Knew that. Just really wondering on if I need to do a relearn
  5. #5 Re: Engine swap
    Swap the rear exhaust manifold
    You can use the evap from the new motor as long as you don't have a 97
    Swap your MAP sensor onto the new motor (or change your plug to the L32/L36 one)
    Flexplate should be dual drilled, so no worries there
    TB, you'll need an adapter to go from Gen V to L67 or whatever other one you choose
    PCV will need to be run from the nipple on the back of the Gen V to the correct spot on the TB. Outlined in this thread
    http://www.grandprixforums.net/threa...ighlight=drill
    That should get you there.
  6. #6 Re: Engine swap
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Shouldn't have to. Same engine with slightly different internals as far as I'm aware. Just different rods and pistons but should otherwise be about the same. Besides Gen V instead of our Gen III
    Sent from my SM-N900P using Tapatalk
  7. #7 Re: Engine swap
    Aug 2011
    Michigan
    ^^ Or this man has all the info you'll ever need xD
  8. #8 Re: Engine swap
    Quote Originally Posted by tomtom123 View Post
    I'm BillBoost... what can I say, done way too much work on these cars
  9. #9 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    How do I do a crank relearn? I'm swapping my gen 3 on with the intake. And either will sell it or wait to save for the adapter
  10. #10 Re: Engine swap
    You won't need a relearn to start and run.
    Relearns can be done with DHP, HPT, Aeroforce or dealer
  11. #11 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    Okay. So it will run fine with out crank relearn. But I still need to get one done soon?
  12. #12 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    Okay. So the guy I was getting the "supercharged" from. Just sent me a picture. Well it's not supercharged. Worth it to top swap it?
  13. #13 Re: Engine swap
    whats he charging? not to much i hope.
    top swap needs new head gaskets and new bolts. and it maybe wise to have your old heads looked over, new valve seals and springs at least.
  14. #14 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    I told him is give him 100 nothing more
  15. #15 Re: Engine swap
    thats not bad if he takes it. off sets the price of the extra new parts and gaskets. i'd re gasket most every thing, back of the engine, the crank seals, front and back, the oil pan, maybe even the timing comer. its all easy with the engine out of the car.
  16. #16 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    He told me I insulted him lol
  17. #17 Re: Engine swap
    Quote Originally Posted by 98buicksupercharged View Post
    what does he think is fair? lol around 300 would be the norm.
  18. #18 Re: Engine swap
    Oct 2012
    Fort Wayne, Indiana
    Well back to finding a new motor
  19. #19 Re: Engine swap
    300 is what I would pay. You need a motor don't insult him by offering $100 rather if it's sc or n/a. You still have all your good parts to swap over.
    04 Comp G.
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
