Thread: Oil leak
Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 218
  1. #61 Re: Oil leak
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Got it to run again. It sits at like 500 rpms as long as I hold about half throttle. Then after a minute of that it started to rev closer to 1k but the entire time it was super rough! Like the engine was jumping. It acted worse than my previous engine that had a blown piston 3. But this engine ran fine when I had the oil leak and I had the heads off before and the pistons/rings are fine..
    Sent from my SM-N900P using Tapatalk
  2. #62 Re: Oil leak
    you check the fuel pressure at the rail yet? sound slike its starving for fuel.
    or the spark plugs are completely fouled from be gas soaked.
  3. #63 Re: Oil leak
    Aug 2011
    Michigan
    There was pressure in the fuel rail. Spark plugs seem rather clean
  4. #64 Re: Oil leak
    Test your fuel pressure!
    04 Comp G.
  5. #65 Re: Oil leak
    run it again if you can for a minute, then pull the front plugs out see how they look, blackened, brown, white? wet or dry.
  6. #66 Re: Oil leak
    heres a shot in the dark, try the high speed relay by pass trick, it puts the pump in hi speed mode.
  7. #67 Re: Oil leak
    Aug 2011
    Michigan
    Here is 1, 3, and 5
    They are dry
  8. #68 Re: Oil leak
    Aug 2011
    Michigan
    I don't have an adapter to test my fuel pressure with. Well I don't think. I'll check the basement
  9. #69 Re: Oil leak
    try the relay trick yet?
    and you really need to test your pressure at the rail, the tester is less then 20 bucks at the parts store, or they do the free rental deal for them too.
  10. #70 Oil leak
    Harbor freight bro or go get a loan a tool from the parts store. Time to stop assuming and guessing and get things monitored to make sure that it's not a fueling issues
    Edit: damn it Scott if you ninja me one more time >_<
    04 Comp G.
  11. #71 Re: Oil leak
    Aug 2011
    Michigan
    Here's something though. Car ran pretty decent, I disconnected the battery and removed the crank pulley and replaced that seal, put the car back together and now this? I'm confused I guess
    Edit:
    The parts store is about 35 miles away. So if I leave now I'll get there on time. I'll see if I can borrow a car to run there possibly
  12. #72 Re: Oil leak
    Could be a coincidence. I would also go back and check the CPS as well as the wiring and maker sure that it's not broken or cut. N Najee sure the. HB is on straight and that it's not warped
    04 Comp G.
  13. #73 Re: Oil leak
  14. #74 Re: Oil leak
    Aug 2011
    Michigan
    Okie dokie. I'll check the sensor while my grandpa is looking for an adapter to fit the guage to the fuel rail.
    Meanwhile, here is a picture of the sensor. Can I check to see if the HB is warped with the car off?
  15. #75 Re: Oil leak
    Aug 2011
    Michigan
    By the way, I just want to thank everyone for helping and offering advice and support. I really appreciate it
  16. #76 Re: Oil leak
    thats the plug, the sensor is behind the balancer.
  17. #77 Re: Oil leak
    Aug 2011
    Michigan
    So to check the sensor.. I have to pull the balancer again?
  18. #78 Re: Oil leak
    correct sir. maybe replace it for the hell of it, or maybe its just full of oil from the leak and it needs to be cleaned off. hard to say.
  19. #79 Re: Oil leak
    Aug 2011
    Michigan
    I felt inside of it and it didn't feel wet, and when I had the balancer off the sensor/the plastic piece inside that the balancer rings sit inside were dry
  20. #80 Re: Oil leak
    hard to say, that sensor does control the spark.
    so if its got fuel pressure 40 plus psi key to run, and holds over 40 when its running the pressure is good. any less is a problem.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
