Thread: Oil leak
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 41 to 60 of 218
  1. #41 Re: Oil leak
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Thanks guys!
    Now the car won't start... Lol xP
    Sent from my SM-N900P using Tapatalk
  2. #42 Re: Oil leak
    did you clean the crank sensor up, plugged it back in, no damage to the harness?
  3. #43 Re: Oil leak
    Aug 2011
    Michigan
    I didn't unplug any sensors =o
    Checked and the crank sensor is nice and snug
  4. #44 Re: Oil leak
    Aug 2011
    Michigan
    Car was running rather well, pulled the belts off, the balancer off, put the new seal on, balancer back on, belts back on, car turns over but no higher than 1 - 200 rpms
  5. #45 Re: Oil leak
    very odd..... all i can think of is the sensor got oil on it. but its reading the rpm's when cranked.
    check for fuel and spark, see whats missing.
  6. #46 Re: Oil leak
    Aug 2011
    Michigan
    Pump primes. Its acting like the battery is dead. Even though the battery has been charging on and off all day..
  7. #47 Re: Oil leak
    So did you check the voltage
    04 Comp G.
  8. #48 Re: Oil leak
    Aug 2011
    Michigan
    At the battery?
  9. #49 Re: Oil leak
    also check the battery connections, and the grounds. try a jump start.
    make sure you got fuel and spark too.
  10. #50 Re: Oil leak
    Aug 2011
    Michigan
    I can't check for spark now simply because the battery acts as if it is completely dead now. Turn key on and it clicks once at the starter and then nothing else.
    I removed and checked the positive battery connection and it looked fine. Doesn't look dirty or corroded or anything. I didn't remove the negative because I didn't touch that one when I went to change the seal at the crank. I removed the positive connection so I could move the fuse box around and what not to reach the tensioner for the engine belt better. But I'll check the negative connection too.
    To check for fuel do you want me to make sure that the rail is pressurized? I can hear the pump kick on every time I turn the key to on
  11. #51 Re: Oil leak
    see if you have 12 volts min at the battery.
    try a jump start yet? the lights come on, horn blow loud? inside lights and dash stay lit after it goes click? or the key stuck forward after the click due to weak or lack of power?
  12. #52 Re: Oil leak
    Aug 2011
    Michigan
    At the battery
  13. #53 Re: Oil leak
    Looks like foreign technology
    04 Comp G.
  14. #54 Re: Oil leak
    Aug 2011
    Michigan
    The car turns over now. Juat 100 - 200 rpms. It will turn over and turn over and turn over but never start
  15. #55 Re: Oil leak
    whats the black fat wire with al the copper showing? if thats part of the car its a huge no no.
  16. #56 Re: Oil leak
    Aug 2011
    Michigan
    Its getting fuel. Pulled a spark plug and it was somewhat wet with gasoline.
    It's getting spark. I pulled a plug and wire and set it up where I could see it as I turned the car on I saw it spark
    Battery is giving plenty of voltage.
    Not sure what the next step is
  17. #57 Re: Oil leak
    Aug 2011
    Michigan
    Oh no, its a part of my stereo system that I didn't finish because the amp I had was no good. I never finished the wiring so I just put that wire on the reservoir bolt to keep it out of the way =P
  18. #58 Re: Oil leak
    this a 97-03? if so crank it with the gas pedal to the floor it may clear it out and fire up.
  19. #59 Re: Oil leak
    Aug 2011
    Michigan
    Yeah. 99
  20. #60 Re: Oil leak
    Aug 2011
    Michigan
    So I got it to run a little bit. If you want to call it 'running'. It hiccuped to life and I had to keep pressing the gas to keep the car running and even then it only revved to about 500rpms. Then after I got out of the car it slowly spit and sputtered to its death.. Not sure whats going on.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
