Thread: supercharger swap now high idle
Results 1 to 20 of 20
  1. #1 supercharger swap now high idle
    Apr 2014
    Albuquerque New mexico
    I just put a new supercharger on my 2003 gtp, I ported the supercharger before i installed it and it also has a 3.5 pulley on it. For other back ground on the car it has a aftermarket down pipe with a highflow cat, a hot ait intake, 103's, and a 180tstat. I also have a scan gauge set up to read knock and the most i have seen on this set up is 2.5* with it about 90* out.
    Now to the problem. The car is idling between 1000-1400 rpm in park ad down to 1000 even in gear. I've done a few things since the high idle to include spraying carb cleaner abound every vac line and around the supercharger and throttle body gasket. I also removed and swaped the iac off of a properly running 3.8 and still have the same problem. Also another thing that bothers me is that the evap purge is running like crazy, i also swapped this off the other properly running 3.8.
    The only thing that i can think of so far is that there is an extra port on this m90 next to the air inlet at the rear of the supercharger and i capped both of those open ports off.
    Any advice is greatly appreciated and would love to not have to take it to a shop
  2. #2 Re: supercharger swap now high idle
    Did u have it tuned for the ported sc?
    04 Comp G.
  3. #3 Re: supercharger swap now high idle
    What?
    Why would you even need to do that lol.
    Unhook your throttle cables and see if the idle returns to normal.
    So you did a gen v swap? I assume thats what it is because you talked about a rear port on the case, and I know the 98-03 didnt have one, only the 3 line vacuum tree ontop.
  4. #4 Re: supercharger swap now high idle
    Apr 2014
    no its not a gen 5, ill try and find a picture.
  5. #5 Re: supercharger swap now high idle
    Apr 2014
  6. #6 Re: supercharger swap now high idle
    you have a 97 blower there, cap those two ports on the tree. thats your vac leak.
  7. #7 Re: supercharger swap now high idle
    Oh, thats a 95-97 style superchrger with those silly vacuum towers.
    Capping it should be fine, just make sure you have the map going to the intake, then over the FPR and to the boost solenoid and it looks like you do.
    I'd still try messsing with the throttle cables.
  8. #8 Re: supercharger swap now high idle
    Apr 2014
    i have the ports capped because i figured thats all they were, it still has the high idle. and yes the map is routed to the lower intake. I dont know where else to go from here. I havnt messed with the throttle cables but i wil do that. it is showing 0 on the tps though. not sure how accurate that is.
  9. #9 Re: supercharger swap now high idle
    Apr 2014
    is it possible it can be related to the purge solenoid constantly purging? when i pull the connector for it the idle drops down and then climbs back up a few seconds later.
  10. #10 Re: supercharger swap now high idle
    Is it possible you can rule out the throttle and cruise cable before you keep asking us for potential items to cause it?
    We like to start off with the easiest items that may be causing the issue and then work our way into the items that will cost you the most time and money. If you'd like to skip right to most money.. replace your motor and then we will diagnose the high idle on the new motor.
    Please stop pulling connectors off when you have no idea what the reaction of the item should be. This will only upset the pcm and cause it to counter act you messing around with sensors etc.
  11. #11 Re: supercharger swap now high idle
    Apr 2014
    Okay will do the only reason for pulling the purge was I had read that it can cause high idle.
    Today after work I will pull the cables and see what happens
  12. #12 Re: supercharger swap now high idle
    Things that cause high idle.
    Vacuum leaks - however you said you checked for them with tb cleaner.
    IAC - no reason this should have magically started having trouble with the swap
    Cables - they do a loop on the strut tower and .. sometimes a slight move can cause them to cause this issue
    Screwing around with something that you didn't change doesn't make a lot of sense. Typically if a car was just worked on, look to the areas in and around the work. Electrical items/sensors won't usually mess up from being unplugged and plugged back in. However if you unplug/plug in while the ignition is on.. it can get a reaction from the pcm.
  13. #13 Re: supercharger swap now high idle
    Apr 2014
    I didnt unplug anything while it was running until after the problem. It almost seems to be intermediate now. The car is staying in closed loop mode like it should and the upstream o2 is not even two weeks old. My gas mileage is also dropped by like 10 mpg I know there will be some drop with the smaller pulley but I am pretty sure it shouldn't be this much
  14. #14 Re: supercharger swap now high idle
    post some more pics of your vac lines and the routing you have set up.
  15. #15 Re: supercharger swap now high idle
    Apr 2014
    okay i will tomorrow. im pretty sure its all correct but a second set of eyes is deffinitly worth a try. Its idling at 1200rpm right now and the vac at idle is -8.2 lbs according to the scan gauge.
  16. #16 Re: supercharger swap now high idle
    If you scanner can read MAP in/hgs, thats far better than trying to read it in lbs which is normally wrong.
    Vacuum off the map sensor should be -19 to -20ish at idle, which is 700-800 rpms.
  17. #17 Re: supercharger swap now high idle
    How did the cable unhook go? I'm assuming it didn't fix the issue or you'd have said something?
  18. #18 Re: supercharger swap now high idle
    Apr 2014
    Yeah there was no change with unhooking both cruise and throttle cables. After work today ill get pictures of vac lines.
  19. #19 Re: supercharger swap now high idle
    Which SC gasket did you use? Get the surfaces clean?
  20. #20 Re: supercharger swap now high idle
    Apr 2014
    I used a felpro from napa, looked the same as what was on it, and I at cramped both the sc and lower intake clean with a scraper and flat razor
  1. High Idle
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2013, 11:12 PM
  2. High Idle/Stuck in 1st after motor swap
    By Dtrick22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2013, 12:06 PM
  3. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  4. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
