Thread: Flexplate is trash....
Results 1 to 20 of 25
  1. #1 Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Started the car today and heard this terrible grinding noise coming from the trans and flexplate area inspect it and its the flexplate... smh.. so any ideas on making this the quickest flexplate install I know I have to pull the motor out but can I just pull the motor a few inches up to do it do I have to pull the motor all the way out the bay? Thanks!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Flexplate is trash....
    Dec 2012
    troll land
    slide the trans over, depends on how squirrelly u r
  3. #3 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by l67ss View Post
    Its about 11 bolts correct? Or 8? I cant pull the a tad bit to make it come out ?
  4. #4 Re: Flexplate is trash....
    Dec 2012
    troll land
    6 bellhousing, 3 tq converter, 3 intermediate shaft bracket,2 trans mount, and then undo cvs
  5. #5 Re: Flexplate is trash....
    Where's the 6th bell housing? 3 intermediate shaft? you mean 4?
  6. #6 Re: Flexplate is trash....
    would be way faster to drop cradle for that job would suck balls to do try do it with the cradle still in the car. Just my 2 cents. Ive done entire trans swap with a lift in less than 6 hours on a na car.
  7. #7 Re: Flexplate is trash....
    pretty sure people have just split the motor and tranny in the engine bay, hang the engine with a hoist, support the tranny. split em in the bay, you wont have a ton of room to work in but should be enough.
  8. #8 Re: Flexplate is trash....
    Dec 2012
    troll land
    this^
  9. #9 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Ok..
    I was gonna try that shouldn't be too bad
  10. #10 Re: Flexplate is trash....
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    ^My friend was out of a garage and had his go and the shop didn't pull the engine or trans they did this trick.
    04 GTP -HAI, 1.9 rockers.
  11. #11 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by SnowTh1ef View Post
    What trick?
  12. #12 Re: Flexplate is trash....
    You don't have enough room in the bay from everything I've done in there. Maybe if you yank off the motor mount.. you can squeak the motor over 2-3 inches.. but damn that'll be super tight.
  13. #13 Re: Flexplate is trash....
    Screw the dicking around and no space to work with think you can do the squeeze job in less than 6 hours? I bet you spend half that time pissed off because you have no room to work! Job like that having room makes it all go together quick. If you pay attention very little needs to be disconnected if the cradle is down just enough.Why work on a creeper under the car when you can look at the engine and trans at knee height? Good luck no way in hell id try squeezing a flex out with the cradle still bolted in. By lifting the car over the cradle that trans comes out the drivers wheel well and back in driving out in less than 6 hours, think about it transmission is alot shorter than the engine that cradle doesnt have to be seperated by much.
  14. #14 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Still tryna diagnose what's wrong if the flexplate wasnt cracked or broke the car would be able to be driven right guys? 3800's guru's step in vid below when I rev it the sound goes away though
    http://youtu.be/mXUSY_uqj74
  15. #15 Re: Flexplate is trash....
    Quote Originally Posted by jayroca View Post
    make another vid, take the throttle and hold it at 2000 to 2500 rpm for a few seconds, then drop the throttle. let it go right back to idle.
    that will be much more telling vid.
  16. #16 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Ok
  17. #17 Re: Flexplate is trash....
    Link doesn't work for youtube.
  18. #18 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Try it again
  19. #19 Re: Flexplate is trash....
    Dang all I hears is cam and engine running.
  20. #20 Re: Flexplate is trash....
    Banned
    Jan 2013
    maryland
    Lol thats the noise .. sound like rocks inside the block really loud
  1. Throwing all my GTP parts into the trash
    By BobC in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 08-13-2011, 06:42 AM
  2. Flexplate, how much, how to, and where.
    By aeidian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2010, 10:43 PM
  3. Replies: 35
    Last Post: 04-21-2010, 09:27 PM
  4. trash talking GTP's
    By 98bullit in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 10:52 PM
  5. L26 Lifters and Flexplate in L67?
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 12:13 AM
