Thread: 2004 gtp comp g abs/stability/traction light
Results 1 to 10 of 10
  1. #1 2004 gtp comp g abs/stability/traction light
    Aug 2013
    Waterboro, ME
    Chats
    All three system lights come on now at the same exact time. Used to happen once in a great while, now it's very common. Is it just an abs sensor? If so how much would a fix be?
  2. #2 Re: 2004 gtp comp g abs/stability/traction light
    Oct 2011
    Toledo, OH
    Chats
    956
    Yep, probably ABS sensor. Need a whole new bearing. Less then $100 but you gotta find out which one it is.
    7"
  3. #3 2004 gtp comp g abs/stability/traction light
    Chats
    78
    Find a local shop that can scan for abs codes and pay a few bucks and let them scan it and tell you what's wrong. Saves you plenty of time as well as having to play the guessing game. Oh and saves you from replacing parts that may not be the fix.
    04 Comp G.
  4. #4 Re: 2004 gtp comp g abs/stability/traction light
    Aug 2013
    Waterboro, ME
    Chats
    I haven't had is scanned yet and I plan to soon, but I notice that the abs light comes on and the TC and Stability control turns off when I turn the wheel sharply... didn't know if that changes anything
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  5. #5 Re: 2004 gtp comp g abs/stability/traction light
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    Chats
    all 3 will come on at the same time as they all need common wss data for proper operation. when a fault is detected, all 3 system are disabled. turning the wheel flexes the front wss harness at the control arms, possibly causing a signal drop out.
    2004 comp g
  6. #6 Re: 2004 gtp comp g abs/stability/traction light
    Jun 2012
    Ontario Canada
    Chats
    8
    My old man's buick had the same issue, somebody forgot to make sure the connector "snapped" when pushing it in, contact cleaner (from dirty contacts of being unplugged and driven) and a "snap" and it was good to go
  7. #7 Re: 2004 gtp comp g abs/stability/traction light
    Aug 2013
    Waterboro, ME
    Chats
    Sometimes before the systems turn off the abs stays on and when I go to brake regularly the abs kicks on like it senses wheel slip
  8. #8 Re: 2004 gtp comp g abs/stability/traction light
    Jun 2021
    Chats
    The wheel sensor wires leading to the abs computer break about 6in from the plug, usually where the wires sit on top of the control arm. They make a repair kit for it.. I had to replace both fronts on my car
  9. #9 Re: 2004 gtp comp g abs/stability/traction light
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    Quote Originally Posted by mark97564 View Post
    welcome to the forum. while its interesting that you're engaged in the conversations, you've bumped a dozen dead threads that are over 6 or 7 years old.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  10. #10 Re: 2004 gtp comp g abs/stability/traction light
    Jun 2021
    Chats
    I sure did.. I still own a few of these cars and I'm sure others do to so while looking around I figured why not put the fixes on a few that didn't have any
  1. Check Engine Light on 2004 GTP Comp G
    By daltman360 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2013, 09:20 PM
  2. Replies: 25
    Last Post: 01-26-2013, 11:52 PM
  3. Traction Control/Stability System Module
    By teamfbody in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2012, 07:16 PM
  4. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  5. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
