Thread: About to make intake, 3" or 4" piping?
Results 1 to 20 of 27
  1. #1 About to make intake, 3" or 4" piping?
    SE Level Member Daven's Avatar
    Apr 2014
    Saskatchewan, Canada
    Hey guys, just gonna be a simple 45* bend to a 9" long k&n. I read a while back that for a S/Ced one you need 4". But currently I just have my large filter on the end of my MAF and it looks like the sensor is only 3" anyways. So even if I did go 4", there would be no point anyways? Just a bottleneck unless I pointlessly upgraded the sensor size somehow
    Currently, essentially stock. Future mods I hope to be XP cam, headers, whatever pully from there. Maybe IC. But I'm assuming stock wouldn't care with 3" anyhow since the stock bend doesn't look too big either
    Using Tapatalk
  2. #2 Re: About to make intake, 3" or 4" piping?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    3 inch street pipe is what you need. I used a 22.5 for a not so harsh bend 4 inch filter fits perfectly over the larger end of it then a rubber couper stretched over the TB.
    Edit if your 04+ the 22.5 you might have clearance problems because of the MAF but iunno
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: About to make intake, 3" or 4" piping?
    Apr 2014
    Yeah I'm a comercial plumber so I have all this stuff at the shop anyways. Was going to use XFR pvc because it won't burn up like other "plastics". I also think it is a bit more heat resistant too, but I'm not sure and I'll be painting it anyways :P at the moment I have the filter going into the bottom half of the airbox (just took off the top portion) with some tin between the electronics and filter so it doesn't burn up. That's why it looked to me like more of a 45*
    So has anyone heard of 3" being "too small"?
    Using Tapatalk
  4. #4 Re: About to make intake, 3" or 4" piping?
    Stock size is near 3in and you'd never outflow that stock or even when modded on just about any car.
    Don't over oil that K&N filter either, it can kill the MAF sensor, I prefer dry flow filters myself.
  5. #5 About to make intake, 3" or 4" piping?
    Apr 2014
    Yeah I've been through that before. This ones a brand new filter though so hopefully from factory they aren't overdone. So from stock to that cone would you have noticed any change? I know I used a 3" filter first on the end of my maf, but it was a really short one off my old 3.4l Grand am so it restricted things way too much. This beast of a filter helped though but now I haven't gone from stock right to this setup
    Using Tapatalk
  6. #6 Re: About to make intake, 3" or 4" piping?
    Just a sound change will be heard from the larger filter over stock.
  7. #7 Re: About to make intake, 3" or 4" piping?
    Apr 2014
    Yeah only reason I did it. I'm only replacing that little stock bend because I figure the smooth pipe will help the sound a bit more over the stock rubbery and ridged bit lol
    Using Tapatalk
  8. #8 Re: About to make intake, 3" or 4" piping?
    plain old cheap pvc street pipe works just fine, no melting whats so ever, and its painted with rustolium black paint and its still there. in take temps are over 120 most of the time, and higher.
    its tight on the right side there but you can see the piant is still there. the coupler has been replaced last year it only lasted about 3 years. the paint is about 4 years old now.
  9. #9 Re: About to make intake, 3" or 4" piping?
    Apr 2014
    Looks like you used a 90* bend. I'll have to see what we have around for couplers, I might just cut one so It doesn't bring it out so far to need a tight bend. Thanks for the input guys!
    Using Tapatalk
  10. #10 Re: About to make intake, 3" or 4" piping?
    coupler is a rubber pipe coupler that had the metal cover over it, tear the metal off the clamps and thats what you have left. this one i got from lowes and is much thicker then the one i got at first from home depot first.
    and yup thats a 90, my h/d didnt have a 22.5
  11. #11 Re: About to make intake, 3" or 4" piping?
    Oct 2011
    Toledo, OH
    You don't even need a bend with a 9" filter on the 04+.
    TB - 3"IDx4" straight coupler - MAF - filter.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  12. #12 Re: About to make intake, 3" or 4" piping?
    Apr 2014
    So the TB and maf are both 3"? So I couldn't see any real point to 4" at all lol
    Using Tapatalk
  13. #13 Re: About to make intake, 3" or 4" piping?
    the 4 inch comes into play because thats the fat side size of the street elbow.
    air filters come 4 inch or 3 inch, some like spectra has a 1 inch ring to make the filter fit 3 inch or 4.
  14. #14 Re: About to make intake, 3" or 4" piping?
    SWPA
    When you use 4" is acts like a charge pipe.
    Also there is NO ISSUE with oiled filters, none, nada, zip, zilch. The only time there is ever a problem is when people clean them and reoil them and put too much oil on themselves. That is not the fault of the filter. I have been running oiled filters for 13+ years and have never had a MAF problem. I know many, many people who run oiled filters and not one of them has had any issues either.
  15. #15 Re: About to make intake, 3" or 4" piping?
    Aug 2013
    McDonald PA
    Stealthee what diameter is our 04+ tb
  16. #16 Re: About to make intake, 3" or 4" piping?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Make sure you check the rubber coupler and clamps pretty often after installation. Mine loosened up a few times and I had to tighten the clamps again, but after the second time I never had a problem.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  17. #17 Re: About to make intake, 3" or 4" piping?
    SWPA
    Quote Originally Posted by Theaceofspades View Post
    It's an odd one. I would need to check to see if I can find my stuff from when I ordered couplers.
  18. #18 Re: About to make intake, 3" or 4" piping?
    Apr 2012
    Dayton, OH
    Should be the same as 97-03 a bit over 3"
    2012 F150 STX
  19. #19 Re: About to make intake, 3" or 4" piping?
    SWPA
    Quote Originally Posted by ILoveGM View Post
    The coupler may have just shrunk on you. I didn't have that issue, but I can see it happening.
  20. #20 Re: About to make intake, 3" or 4" piping?
    SWPA
    I just looked up my history. I used 3.25 to couple the MAF to the TB.
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
  2. Dyno Science: "CAI" Box vs Open Cone Intake
    By SlowNA06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2016, 12:29 PM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  4. 2" intake piping??
    By blazer2002 in forum General Tech Discussion
    Last Post: 06-06-2009, 12:11 AM
