Thread: Fixed my GTP! Time for mods.
Results 1 to 14 of 14
  1. #1 Fixed my GTP! Time for mods.
    SE Level Member Konvinced89's Avatar
    Layton, UT
    For those not familiar with my angry rants, my car had an intermittent rough idle/stalling issue for years, and I replaced nearly every sensor in the engine with no results. MAF, MAP, TPS, CPS, IAC, plus the fuel pump/filter, and a bunch of other things. Short version: I had it down to the PCM or wiring, and I got an Overkill PCM. Problem solved!
    Now, I want to get back to the fun part of owning a GTP. My other mods are a K&N intake, 180* tstat, modular pulley system(3.8 for now), 104 plugs, ubend delete, resonator delete, and Magnaflow mufflers. I've kept up on the maintenance, and my goal is an additional 20-30 HP, and a couple tenths off my 1/4 mi. I'm pretty sure the next step is headers, Will said I'd be good to pulley down after that. I just want to make sure I'm not forgetting anything.
    Also, I have a lot of drone with my mufflers; can anyone recommend a good way to reduce drone without it sounding totally mellow? I just want to quiet it down some, especially if I'm going to put headers on. Thanks in advance for any helpful advice.
    03 Ivory White GTP: Overkill PCM, MagnaFlow, ubend delete, 3.4/3.8 MPS, AGX/B&G, Buick strut bar, and a big \*/ sticker so they know what just whined by.
  2. #2 Re: Fixed my GTP! Time for mods.
    Aug 2013
    McDonald PA
    Well the Rez delete caused the drone. And yes get headers
  3. #3 Re: Fixed my GTP! Time for mods.
    Aug 2013
    McDonald PA
    To fix it add the biggest glass pack you can to were the Rez used to be
  4. #4 Re: Fixed my GTP! Time for mods.
    Layton, UT
    And the drone goes away? What brand would you recommend?
  5. #5 Re: Fixed my GTP! Time for mods.
    Aug 2013
    McDonald PA
    Cherry bomb thrush whatever you want. And yes he majority of the drone will go away that's what the Rez does
  6. #6 Re: Fixed my GTP! Time for mods.
    May 2012
    Where winter never ends
    Get headers, drop a pulley enjoy, intercool/cam, drop more, enjoy, turbo, enjoy.
    2000 Regal - Winter Beater
  7. #7 Re: Fixed my GTP! Time for mods.
    Layton, UT
    I'm at 4600ft above sea lvl, and my best 1/4mi run was a 15.2, which was before the overkill tune on a 3.4 pulley. Now it doesn't like the 3.4, and I haven't had a chance to run it on the 3.8. I'm hoping headers + 3.4 pulley will get me in the high 14s. Reasonable?
  8. #8 Re: Fixed my GTP! Time for mods.
    Plugs are too cold for 3.8 and 180 is unneeded too.. put that moola into a real mod.
  9. #9 Re: Fixed my GTP! Time for mods.
    If the Overkill tune is set up for the 180* leave it in there though. And yes 104s are way too cold, you should be running Autolite copper or irridium 606s iirc or some ac delco 41-110 iirc.
  10. #10 Re: Fixed my GTP! Time for mods.
    Layton, UT
    I might be wrong...I'll have to check the box, I might've put iridium 605's in last time. I went through three sets of plugs trying to fix my rough idle, when all the while it was that darned PCM. I had copper 104's last time because I was planning to get headers shortly and run the 3.4 pulley, but I believe they are 605's now.
  11. #11 Re: Fixed my GTP! Time for mods.
    Oh yeah sorry I do believe its 605s not 606s.
  12. #12 Re: Fixed my GTP! Time for mods.
    Layton, UT
    So after headers and 3.4 are in, go back to 104s?
  13. #13 Re: Fixed my GTP! Time for mods.
    Yeah.
    Sent from A Galaxy Far Far Away........
  14. #14 Re: Fixed my GTP! Time for mods.
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Autolite Copper 606's are the stock heat range so thats probably what you should run intil your headers are in and 3.4 is on =]
    Sent from my SM-N900P using Tapatalk
  1. Looooong time GP owner, first time GPF member
    By Brian G in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 06:04 PM
  2. Estimated Drag time of my car wiht current mods
    By screamingreenmonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 12:54 AM
  3. Time for a spring tune-up and some basic mods
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 03-11-2010, 10:32 PM
  4. Need opinions on spring time mods
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 12-13-2009, 10:57 AM
  5. The time for mods are approaching.
    By Merlin in forum Brakes/Suspension/Chassis
    Last Post: 08-02-2009, 11:02 PM
