Thread: Will this setup work?
Results 1 to 14 of 14
  1. #1 Will this setup work?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I would like to get a 3.5 Pulley. The 3.4 just seems to much ATM.
    I have a CAI, and a DHP pcm.
    I am going to get:
    U-Bend Delete
    180 T-stat (from auto store)
    Auto Lite 104 Plugs
    3.5 Modular Pulley system
    Belt #658
    In total im prolly looking at somewhere around 220 shipped.
    Also I will need to get the parts installed... Thats going to cost some $. Ill get a friend to install the plugs. U-bend install should be under $100. Pulley and belt installed hopefull I can do myself, although I am worried I will ruin the orig pulley when installed the new one.
    Think this is a good setup?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Will this setup work?
    SE Level Member rfmgtp02's Avatar
    Oct 2008
    Voorhees NJ
    That should work just fine but be sure to scan for kr. I doubt there will be much kr if any at all
    2002 GTP 2DR Red Fire Metallic
  3. #3 Re: Will this setup work?
    skip the u-bend delete and get a 3" downpipe instead. that will take care of the u-bend and give you some more breathing ability on the exhaust side. just the u-bend is kind of pointless if you plan on going any farther with the car than just the 3.5/3.4.
    id say with a downpipe and a plog (from zzp) you can run a 3.4 just fine. youll need a tune to run it right though.
  4. #4 Re: Will this setup work?
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    yeah ditch the ubend delete and find a used downpipe.
    you'll still most likely have KR with either pulley, but still run the 3.5 anyways.
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  5. #5 Re: Will this setup work?
    dont be a weiner..run the 3.4
    what can happen? your car blows up? riiighht..
  6. #6 Re: Will this setup work?
    Bartlett, IL
    Thanks for the info
    I wont be able to tune the car though. I do now know anyone with a tuner also...
    Ill go with the DP but man its going to be $$...
    After this is all said and done, what kind of power increase am I looking at?
    How To: E-Brake Pwn
  7. #7 Re: Will this setup work?
    May 2008
    Saint Louis, MO
    if you consider how much you pay for a ubend piece and a shop to do the welding its about the same cost... as just goin with some catless 3" bolt-in.
  8. #8 Re: Will this setup work?
    Bartlett, IL
    na I have to run cats
    How To: E-Brake Pwn
  9. #9 Re: Will this setup work?
    with a basic 3.4 setup youre looking at maybe 20hp increase over stock at best, but youre going to feel it for sure. it will feel like a whole new animal with just that, trust me.
  10. #10 Re: Will this setup work?
    Donating Users blowfishRus6's Avatar
    g.a.
    downpipe for sure man. used ones are going pretty cheap and you could put it on yourself unlike a ubend delete
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  11. #11 Re: Will this setup work?
    Bartlett, IL
    I just searched the classifieds.
    I cannot find a Downpipe for sale
    Anyone who has any info for me please pm me
    How To: E-Brake Pwn
  12. #12 Re: Will this setup work?
    May 2008
    Saint Louis, MO
    nvm
  13. #13 Re: Will this setup work?
    g.a.
    there is usally some floating around. check a few other websites also.
    if anything i would just wait. mine as well do it right the first time then have to go back and do it again.
    patience is a vertue.
    its slow.
  14. #14 Re: Will this setup work?
    g.a.
    if anything save up for some ebay headers, autocrome i think??? that way you will never have to touch that part of the exhaust again. headers made a world of difference on my car
    its slow.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. My computer setup!
    By x1FastGTPx in forum Off Topic Discussion
    Last Post: 11-30-2008, 04:09 PM
  3. New GTP badging setup
    By DesQ27 in forum Visual/Body Modifications
    Last Post: 10-14-2008, 07:03 PM
  4. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
  5. current setup
    By crshoveride in forum Audio, Security & Visual Electronics
    Last Post: 09-05-2008, 08:40 AM
