03 GTP, L67, 141k miles, open cone air filter
I want to clean my throttle body. I have read and googled and youtubed too much--a lot conflicting information, hoping to find some solid advice/insight to couple seemingly basic, simple questions. FWIW, I am NOT going to seafoam the TB on the car.
1st, the throttle body has coolant ports, so is there coolant in it, that is, if I remove the throttle body is any fluid going spill out?
2nd, the throttle body has MAF sensor, IAC valve, and TP sensor, right?
3rd, I have already removed and cleaned both the IAC valve MAF sensor, but I am unsure about the TP(?) sensor. Should I be concerned about fouling out the TP sensor if leave it in TB while I spray it with TB cleaner? Does removing/replacing TP sensor require PCM or other calibration, relearning, programming, whatever?
I know, total noob questions. Like I said, I've come across all kinds of conflicting info. Today is the perfect day for this, except I have commitments tonight and can't be without my only car. Thanks in advance!
