Thread: high idle with a random misfire
Results 1 to 18 of 18
  1. #1 high idle with a random misfire
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I would like to see what could be causing her to idle high. It idles around 1200 to 1400? She will also randomly misfire every once in a while. What could cause this?
  2. #2 Re: high idle with a random misfire
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I'm sure someone more experienced can and will chime in, but mass air flow, throttle position sensor, vacuum leak. Could probably use a tune up if you haven't already done plugs and wires
    Sent from my SM-N900P using Tapatalk
  3. #3 Re: high idle with a random misfire
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    I had the same problem. Try this. Turn the key on and press the gas pedal to the floor hold it for 3 sec, let off, pump it to the floor 5 times in 7 sec let off Turn key off then start it . See if this fixes the high idle. If not follow Toms suggestions.
  4. #4 Re: high idle with a random misfire
    More info is really needed. You wouldnt go to a shop and say what you said, because they'd just look at you with a dumb look because they have no idea what you are talking about and what you drive.
    What do you drive?
    Any recent repairs/maintence done?
    Modded or stock?
    What else do we need to know about the vehicle to help?
    What have you tried?
  5. #5 Re: high idle with a random misfire
    Apr 2014
    South Haven, MI
    I drive a 1999 Grand Prix with a cammed L67. I bought plugs, wires, oil, and an oil filter but need a day off to install. The car is mildly modded. I havent tried anything tofix the issue because it happened on my way to work today.
  6. #6 Re: high idle with a random misfire
    What cam is in it?
    04 Comp G.
  7. #7 Re: high idle with a random misfire
    Apr 2014
    South Haven, MI
    NIC cam
  8. #8 Re: high idle with a random misfire
    Apr 2014
    South Haven, MI
    Quote Originally Posted by lewis1952 View Post
    Is that some kind of idle re-learn?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  9. #9 Re: high idle with a random misfire
    Sep 2013
    tulsa okla
    yes it fixed my high idle problem
  10. #10 Re: high idle with a random misfire
    With a NIC cam, the code P0300 needs to be shut off.
    But I think you need to start with swapping those parts and looking for a vacuum leak. I'd hope you have some sort of scan gauge or whatever to help montior what the car is doing.
  11. #11 Re: high idle with a random misfire
    gardner,mass
    How do you know its misfiring? Is there a code or are you scanning for misfires?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  12. #12 Re: high idle with a random misfire
    Apr 2014
    South Haven, MI
    The code was P0300
  13. #13 Re: high idle with a random misfire
    P0300 needs to be turned off for most cams
    04 Comp G.
  14. #14 Re: high idle with a random misfire
    Apr 2014
    South Haven, MI
    I also found out I need a new tps. Would low fluid in the trans make is shift horrible. I thought my pcs was going out but I found my trans dipstick was very loose.
  15. #15 Re: high idle with a random misfire
    Dec 2012
    troll land
    Yes low fluid will cause shift issuez
  16. #16 Re: high idle with a random misfire
    Dec 2012
    troll land
    Also what does the rpms drop to in gear?
  17. #17 Re: high idle with a random misfire
    With that cam, was any programming down to the pcm?
    I've seen idle be vacuum leak, throttle/cruise cables bound/out of place on strut tower, TPS, tuning
  18. #18 Re: high idle with a random misfire
    Apr 2014
    South Haven, MI
    It was my TPS. When it was tuned, they didn't remove the misfire code.
  1. Random misfire
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 02-01-2014, 04:22 AM
  2. Po170 Po300 Po560 system too lean , random cylinder misfire and iac rpm idle higher
    By mpiacc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2013, 11:34 AM
  3. Random very high / fast idle speed...
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2013, 10:55 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. Random dieing at idle + occasional misfire = me pissed off
    By mark455 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 09:22 PM
